Old 06-27-2007, 04:56 PM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Best way to dissconnect steering column?
Hello...I am getting ready to remove my cab and I need to disconnect my column from my steering box...Where is the correct way to do this??
Thanks for you help...
Clint
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 06-27-2007, 05:45 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Best way to dissconnect steering column?
Disconnect the rag joint is the only place I've ever done it. Be careful while pulling the cab, the bottom of the column hangs on everything.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-27-2007, 06:17 PM   #3
1969k10stepside
2 bolts holding the steering columns intermediate shaft to the steering box..Or you could disconnect it at the front of the firewall by removing one bolt.Then the shaft should slide out from the column.
1969k10stepside is offline   Reply With Quote
Old 06-27-2007, 06:21 PM   #4
cdowns
cdowns's Avatar
i've always just undone the clap at the splined end of the column and left the intermediate shft and ragjoint in place
Old 06-28-2007, 12:05 PM   #5
COACHMEASON
Keep On Keepin' On
So I guess there is more than one way to skin this cat...
07 Avalanche Z71
Old 06-28-2007, 05:34 PM   #6
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
All I did was remove the Screw at the bottom of the column just before it goes into the gearbox and loosened the gearbox on the inside of the frame a little. It was easy getting it apart. Had a blast getting it back in but it worked.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
