Old 06-27-2007, 06:12 PM   #1
abadsvt
abadsvt's Avatar
Shaving the drip rails questions
Hello everyone! I am finally back working on my truck I have started to shave the drip rails when i started looking at the inside of the door jamb. How are you guys cleaning up the edges after you weld. The drip rail connects to the inside of the door jamb and after you remove it, it leaves and extra 1/16-1/8" door gap. Does that make sence? Also does anyone have "progress" pics of shaving there drip rails. Thanks alot!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 06-27-2007, 06:20 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Shaving the drip rails questions
I am interested in this also it would make a GR8 FAQ Tech.
I have seen some different ways but, personal experiences would be GR8.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-27-2007, 06:24 PM   #3
1lowdiesel
1lowdiesel's Avatar
i was thinking about running some 1/8" rod around the door and over the windshield then making it seamless. it would get rid of the driprail and give it a nice radius all the way around and solve the door gap problem.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-27-2007, 07:25 PM   #4
Rokcrln
Rokcrln's Avatar
Lemon Drop http://67-72chevytrucks.com/vboard/s...d.php?t=200082
End of page two and start of page 3 should give you idea. But you will be using flat bar, round rod and awhole lot of time to get it just right.
Kevin
Rokcrln is offline   Reply With Quote
