______________
![]() Join Date: Sep 2006
200r4?
Anyone running a 200R4? I understand that this has an overdrive, but a much closer 2nd to 1st gear ratio compared to a 700R4.
Any thoughts? |
Re: 200r4?
they are a good tranny if you are not pulling anything, but internals to light otherwise
its all about the +6 inches
Re: 200r4?
200 4R, not R4.
They are the same physical size of a short shaft 350, slide the cross member to the Th400 position, and it bolts right in, same yolk as a Th350 too. Still need the sensitice TV cable and lock up harness/controller. Some will tell you it is better than the 700 R4, others will not. They both have strong points and weak points. |
Re: 200r4?
I know a lot of big HP turbo buick guys use them, so they can be made plenty strong.
Re: 200r4?
Since I have a 200 4R I agree with Andy. Even if I didn't I would agree. I think they have more pluses than the 700 R4.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Re: 200r4?
i ran one for a number of years that was built by www.fbperformance.com never had a problem with towing or hauling heavy loads long distances at high speeds it ran just fine and i ran it without the electric converter lockup too// i guess it went about 70k miles trouble free before i got rid of it and the guy that has it now in back of a bigblock in a suburban is still using it 3years later// generally with performance trannies you get what you pay for
Re: 200r4?
I frequent corvetteforumdotcom. Those guys use the 200 alot, as it is pretty much bolt in with no mods. Alot of the guys seem to like it.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
