Old 06-27-2007, 10:43 PM   #1
1987SierraClassic
Cat-Back dual exhaust - 1989 Burb
I currently have a cat-back dual exhaust on my '89 Burb. It was on there when I bought it and whoever put it in, did a nice job, but now it's rusting to pieces. I'd like to get the same type of system, but all I can find are single systems. I may be stuck having a shop duplicate the system that's there, but I'm thinking that would be big money even if they had the old pipes for a pattern.
Anyone know of an aftermarket cat-back dual exahust for these rigs? I've searched Flowmaster, Dynomax, Edelbrock, Gibson and a few others but I've come up empty...
Thanks!
1987SierraClassic (and the '89 burb of course)
1987SierraClassic is offline   Reply With Quote
Old 06-27-2007, 11:36 PM   #2
BowTieOgre
Re: Cat-Back dual exhaust - 1989 Burb
Man you are absolutely right...I searched the big names and found bupkis! Im about to buy a '90 Burb and im a little miffed there isnt an aftermarket dual setup readily available. Let me know if you find anything and I will do the same.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 06-28-2007, 12:32 PM   #3
kevinr1970
I bought a kit from either Summit or Jegs, think it was Jegs. It was a Dynomax kit either way.
Although it was dual pipes after the muffler, they exit on the same side as stock and it was only one muffler. The kit was aluminized mandrel bent pipes.
Not sure if this what you mean by dual exhaust but it was only like $139 plus shipping. I also had to buy a new cat and an intermediate(?) pipe. All told it was just over $200 shipped.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-02-2007, 10:44 PM   #4
1987SierraClassic
BowTieOgre, if I find anything, I'll let you know. So far, nothin'
Kevinr1970, I've seen the system of which you speak. Mine has a 3" single into the muffer and has two pipes that have a side exit on either side just ahead of the bumper instead of both on one side. Those pipes are 2.25" each. It's similar to the Flowmaster Force II system, but they don't make it my my year truck. I may end up with the 3" single Dynomax system if I can't find what I want.
