Old 04-28-2002, 08:57 PM   #1
69Chevyc10
Post CFM question
I bought a 350 for my 69 C-10 the other day. The engine is out of a 1976 Chevy and I was wondering how many cfm the carberautor is. It has the stock quadrajet on it. Thanks Brian Wolf
69Chevyc10 is offline   Reply With Quote
Old 04-28-2002, 10:52 PM   #2
72sleeper
[]D [] []v[] []D
Post
not to invade on your question but im sure whoever replies knows some about carbs and i dont want to make a post askin the same thing but i got a new 350 with a cam and new heads now i got a 2 barrel on i 500cfm but i waswonderin what size 4 barreli should get,600????
Clint
72 c'10 350ci/400hp
sleeper forever
Clint
72 c'10 350ci/400hp
sleeper forever
72sleeper is offline   Reply With Quote
Old 04-28-2002, 10:58 PM   #3
Pont
I need another Barley Pop
Pont's Avatar
Post
69Chevy, if you can get the number off the carb (should be on the main body running up and down, probably at least 9 digits long) I might be able to tell you what cfm that carb is.
72sleeper, IMO, 600 is just right for street use. Should be an all around good size to run. There are exceptions depending on what you want in a carb and what you want out of it for performance.
67 SWB 4x4 - 396 BB / SM420 4 spd
8" lift / 15x14 Welds & 35X14.5 SSR's
Grants Pass, OR
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 04-28-2002, 10:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
'72, what kind of heads you have...whats the specs on the cam?
'69, while i am not sure, I'm thinkin it is a 750-ish.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-28-2002, 11:02 PM   #5
72sleeper
[]D [] []v[] []D
Post
its 268 duration comp cam not really big butthe biggest i could get with a 2 barrel i might upgrade when i get a new carb and im not sure abut the heads we bought the motor built and it messed uponce at a red light (head) but we fixed em and im lookin for the most perforance gain i can get out of it
Clint
72 c'10 350ci/400hp
sleeper forever
Clint
72 c'10 350ci/400hp
sleeper forever
Old 04-29-2002, 01:56 AM   #6
The Blue Pig
Thread Wizard Since 2002
Post
I am sure all you guys have answered questions about CFM before. CFM is highly overrated, and most people with a dwindle of performance jump right to a 750. If you arent moving the right amount of air, fast, you just wont create enough vacumn to be able to draw fuel efficiently out of a 750. I know of one quick (and somewhat basic) formula you can use, a teacher taught it to me, and holley uses it too. Take your CID, multiply it by the high end RPM you plan on running, then divide that number by 3456, and that will give you a rough estimate of the CFM you should need. However, that equation places your engines volumetric efficiency at 100%, and most naturally aspirated engines are not running 100% v.e. So, say your rings are seated good, and there are no leaks in your system, you are probably running in between 90-95% v.e. So you would take that final number you got from the above equation, and multiply that by .9, and that will give you a rough number to go by. Just a little hint to get you off in the right direction.
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
Old 04-29-2002, 05:45 AM   #7
Longhorn Man
Post
Actually, to bo 100% acurate, an internial combustion engine is not even close to 100% volumetric efficiency. THe closest ones are turboed, and they only get up to about 85%. The rest of us are stuck somewhere in the 60% area.
Old 04-29-2002, 03:02 PM   #8
The Blue Pig
Post
Really? I thought that naturally aspirated engines could be anywhere from 60 like you said to 90 and turboed and supercharged were over 100%, and thats why one had to keep the compression down on a turboed or supercharged engine. But, hey, I never had either, so I couldn't tell ya for sure.
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
Old 04-29-2002, 03:27 PM   #9
Blazer1970
Blazer1970's Avatar
Post
Those Q-Jets are 750 cfm (sometimes referred to as 795 cfm). With a Q-Jet, the primaries are relatively small, and the secondary air door is controlled by airflow demand from the engine, so there is no issue with being over-carbed as some have described above. You could have an over carbing issue with a purely mechanical secondary carb like a Holley double pumper.
Blazer1970 is offline   Reply With Quote
Old 04-29-2002, 06:14 PM   #10
dmnall
dmnall's Avatar
Exclamation
Did the engine come out of a 76 Truck or Car ?? If it came out of a truck, then it is a 750cfm 4MV Quadrajet.
Truck #1 68 Chev LWB Fleet w/ Wood Floor (Sucks Gas and Hauls Ass!) and in process of Body Work...
Truck #2 1994 GMC Sierra SL w/ 4.3L Vortec V6, 4L60E Auto!!
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
