Old 06-28-2007, 11:51 AM   #1
David Flores
David Flores's Avatar
need help with the emergency brake system
Does anyone have pictures of the emergency brake system at the cross member?
thanks
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 06-28-2007, 01:29 PM   #2
chevroletrestoguy
Re: need help with the emergency brake system
This what you need?
chevroletrestoguy is offline   Reply With Quote
Old 06-28-2007, 03:10 PM   #3
David Flores
Sorry, I forgot to mention my truck is a 66 1/2 ton swb.
I believe they changed emergency brake system in the 66 year.
66 c10 swbfs
My Build.
Old 06-28-2007, 03:22 PM   #4
19GMC63
19GMC63's Avatar
anyone have pics of an earlier setup?
19GMC63 is offline   Reply With Quote
Old 06-28-2007, 03:40 PM   #5
hewlett2002000
hewlett2002000's Avatar
i can take pics of my 62 brake setup if you like? just let me know.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-28-2007, 06:55 PM   #6
chevroletrestoguy
Pictured is my 65 lwb setup. Don't know if 66 swb is different or not.
Old 06-28-2007, 08:39 PM   #7
19GMC63
19GMC63's Avatar
I looked under the GMC and I see that crossmember but theres nothing on it.
Guess I need that whole assembly then.
Is it riveted to that crossmember?
Old 06-28-2007, 09:29 PM   #8
chevroletrestoguy
I believe it is. It seems like everything on these frames are riveted.
Old 06-28-2007, 09:56 PM   #9
dallas71
dallas71's Avatar
the 66 has a rod that comes from the passenger side frame that is approx 18" long with a cable guide attached to the end of it for the long cable that goes from side to side. this is a solid piece but i am sure it can be fabricated out of threaded rod os something equivalent. if you need a picture i can get it for you once it stops raining.
check out this link not the greates but it will give you an idea....
http://www.lmctruck.com/icatalog/cbe/0082.asp
dallas71 is offline   Reply With Quote
Old 06-28-2007, 11:51 PM   #10
David Flores
If you could get a picture that would be great.
And I feel ya about the rain. It's flooding where I'm at in Texas.
66 c10 swbfs
My Build.
