how to id rearend
wonder how to id rear end its a 72 5 lug rear
thanks jeff |
Active Member
Re: how to id rearend
you should find stamped on numbers on the drivers side tube 3-12" away from the center section. The date code for the casting will be in the lower webbing. Post your numbers here and we should be able to figure it out
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
It should be a Corporate 12 bolt rear.Or do you want to know the ratio?...here is what one looks like,same axle,just on my 4wd..:
The Older Generation
Read my last post in this thread..... http://67-72chevytrucks.com/vboard/s...d.php?t=246968 LockDoc
Location: vacaville ca, because it as far from indy as i can be
only one choice if its the stock rear. 12b
