06-29-2007, 06:34 PM | #1 |
Too many projects
Headlight conversion
Howdy ya'll, just have a quick question.
I just bought a set of (4) 5 3/4" headlights on fleabay and they don't fit my trim ring, so I'm looking for an alternative. I desire a new sytle bulb (H4 or high/low equivalent) in a 5 3/4" housing. Now, I know I shouldn't have gotten them off eBay, as they look cheap and don't fit the trim ring. I expect to clearance behind the bulb for any kit, but these ones are 1/8"-1/4" too small for my rings! Anyways, I know GMCPauls, LMC, Musclerodz, and some other site vendors also offer the converion kits and was wondering what experiences ya'll have had with them. Even the vendors can chime in. Thank you for the information, I no longer care about the prices. lowrollin70gmc P.S. I already coverted to relays for my headlights.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
06-29-2007, 07:06 PM | #2 |
20' Daredevil (Ret)
Re: Headlight conversion
Not sure what our site vendors offer... I bet you'll find out soon enough, though!
What I can tell you is that major brand name headlamps (Bosch, Cibie, Hella...) will fit perfectly and are top quality. Not the cheapest, but worth the cost imho.
06-30-2007, 04:34 PM | #3 |
Too many projects
I have been looking at Bosch, and I found a 5 3/4" setup, but now I can't refind it! Anyways, it's easy to find 7" (chevys), but 5 3/4" is a real pain for us GMC guys, I guess being better means these kind of headaches.
06-30-2007, 04:55 PM | #4 | |
20' Daredevil (Ret)
http://www.danielsternlighting.com/p.../products.html http://www.rallylights.com/hella/5.75_lo.asp http://www.talbotco.com/e-code_lamps.htm http://www.alfacybersite.com/ACSCibhl.html http://www.classicgarage.com/accesso...headlamps.html
06-30-2007, 07:35 PM | #5 |
Too many projects
You're my hero.
06-30-2007, 08:12 PM | #6 |
20' Daredevil (Ret)
I've been using E-Codes in several vehicles since the early 1970s... Glad I could help!
07-01-2007, 04:27 AM | #7 |
JC Whitney has 5 3/4" lamps with H-4 bulb, 60/55 watt part # SA9319P @ $15.99 each.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). Last edited by GMC Jim; 07-01-2007 at 04:28 AM. |
07-01-2007, 02:58 PM | #8 |
some of these are flat front lenses and some are convex. which of these looks best on our trucks?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
07-01-2007, 03:32 PM | #9 |
20' Daredevil (Ret)
In the eye of the beholder...
I've had both (in different vehicles) and generally prefer convex lenses. For one thing, they're less noticeable -- and true E-codes are not street legal everywhere, though you're unlikely to be busted these days for headlamps.
07-01-2007, 04:19 PM | #10 |
What i was looking at was a headlight that you can change the small halogen light bulb like new cars today
07-02-2007, 08:05 AM | #11 | ||
Licensed to Thrill!
I used to own a 1994 Camaro - they had the crappiest factory headlights known to man. I spent hundreds on different setups and bulbs, so just go with me here. Quote:
DLB |
07-02-2007, 08:05 PM | #12 |
20' Daredevil (Ret)
Hellas are excellent, as are Cibies -- which are a bit spendier than Hellas, but have a slightly different beam pattern, at least in the 7" size. Hellas are a bit narrower with more vertical light (high beam only; both have sharp horizontal cutoff on low beam, and flare up to the right for road signs) -- Cibies don't throw as much light upward, but have a bit wider beam which I prefer.
