Old 09-18-2002, 10:42 PM   #1
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Talking Air bag kit!!!
Well the kit's are ready, finally!! hehe, this is a complete kit. It will have everything you need.
4-bags
4-valves
40' 3/8" air line
20' 1/4" air line
Billet gauge panel, with switches
6 gal tank
compressor
pressure switch
front bag mounts
All fittings
Price will be $1200.00
However if you are interested you can e-mail me at casey@phatcustoms.com with your board name and I will give board members $100.00 off. For a limited time.
Thanks Casey
PHAT Customs
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 09-19-2002, 12:20 AM   #2
Alvin
Never Done?
Alvin's Avatar
Wow, if I had the money (and a coil frame!) I'd be all over that deal. Unfortunately money is tight and I don't have a frame to work with. I'll definately be in contact with you in the future though!!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 09-19-2002, 01:13 AM   #3
Reumster
L.E.D. Freak
Reumster's Avatar
Sounds reasonable.
Does the kit come with brackets and such? My next question is can I put the rear kit on, and then later add c-notch and get full rear drop into C-notch? What's the actual size of the internal orphasises(sp) on the valves
Also I've been following and keeping alot of mag articals on bagging 62-72s and all show you must do some modifications to the steering stops on the lower a-arms. Can you elaberate on this?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 09-19-2002, 02:43 AM   #4
Dropt72Shortbed
Dropt72Shortbed's Avatar
what type of valves and what type of compressor?
Dropt72Shortbed is offline   Reply With Quote
Old 09-19-2002, 02:44 AM   #5
Dropt72Shortbed
oh and lastly, is this stuffing coming through AIM?
Old 09-19-2002, 02:51 AM   #6
nate68
thats hella tempting, if only it wasnt school time. if its still available in like 6 month's i'd probably get it.
how much is shipping on that?
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-20-2002, 11:10 AM   #7
Reumster
L.E.D. Freak
Reumster's Avatar
Whats the word?
(406)675-8082
Old 09-20-2002, 01:04 PM   #8
XXL
Seņor Member
XXL's Avatar
Originally posted by Reumster
...you must do some modifications to the steering stops on the lower a-arms. Can you elaberate on this?
When you dump the air out of the bags, the tie rod assembly will run into the steering stop. You'll need to take the rubber AND the actual steel perch off. The perch is spot welded on. I recommend you use a grinder all the way around the mounting flange just enough to get to metal... so you can see the low spots, which are the welds.
You'll probably want to put some kind of smaller stop back in place to prevent clocking the suspension too far (as you can actually get the inner tie rods high-centered on the center link). I chose not to, and just have a good feel for what my turning radius is.
Kenneth
XXL is offline   Reply With Quote
Old 09-20-2002, 01:11 PM   #9
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Sorry everybody, I was sick yesterday and didn't get on the computer at all.
Alvin, I do have bag mounts for the leaf trucks too, a little more expensive, but I got em.
Ruemster, Yes it includes front brackets, you don't need brackets in the rear. The valves are 3/8" orifice, and I never modified my steering stops. I did however have to eliminate the bump stops completly to get full drop.
Dropt72shortbed, The valves are 3/8" 3 position spool valves rated to 175 psi, the saem valves have been on my truck for years now. Yes I am a CHASSIS TECH authorized dealer, I have never hidden that. I will stand behind the products 100%.This paticular kit is from them, but if your are interested in other brands I have access to them also, such as slam specialties bags ect.
Thanks Casey
PHAT Customs
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 09-20-2002, 01:37 PM   #10
jay-dawg
chevelito
jay-dawg's Avatar
another question. Are the firestone 2500 and 2600 bags 3/8 also?
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 09-20-2002, 02:26 PM   #11
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Cool
Yep, 3/8" orafices on all valves and bags.
68 chevy money pit
51 chevy belair
95 Honda 900RR
