Old 06-30-2007, 07:23 AM   #1
Copper116
Gas gauge reading above full - help
I pulled the instrument panel off my 72 ( basic instrument panel ) for various reasons...and after I put it back in, the gas gauge needle went over the full mark and stopped appr. 1/2" above full and there it stays. Any ideas why and how to correct this???
thanks.
Copper116 is offline   Reply With Quote
Old 06-30-2007, 01:15 PM   #2
jhow66
jhow66's Avatar
Re: Gas gauge reading above full - help
Do anything to panel other then remove and replace? Past full means that the tan wire from panel to tank unit is open some where.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-30-2007, 01:22 PM   #3
jhow66
jhow66's Avatar
Remove this plug and ground the spade where it came off of. Gauge should go to empty. If not your problem should be in the connector to gauge panel. Wiggle it to see if that makes it work. (It did work before -right?)
Old 06-30-2007, 10:01 PM   #4
Copper116
I didn't do anything to it.. I only removed it to get to other things. I'll ck the wires again and thanks for the tip.
Old 07-01-2007, 11:16 AM   #5
Luba
Luba's Avatar
Quick question on that pic. In the upper right corner what is the red,green, and black connector that is hooked to the silver thingy? I have that plug but it is unhooked and there is no place to plug it into.
Luba is offline   Reply With Quote
Old 07-01-2007, 12:16 PM   #6
RckyMntnKng
RckyMntnKng's Avatar
On mine that is the relay or switch for the horn
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 07-01-2007, 02:24 PM   #7
orangeuavol
GO VOLS!
orangeuavol's Avatar
R'M'K' is right-horn relay -black wire goes to steering wheel-red wire to power source-green goes to horns.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 07-01-2007, 08:09 PM   #8
Copper116
I haven't had time to try it yet but thanks again for the reply.
