Old 06-30-2007, 07:27 AM   #1
70GMCer
70GMCer's Avatar
Water pump hose ?
I have a 1985 Corvette aluminum short water pump for my 383 build and noticed that the radiator hose connection on the pump is smaller than the hose that goes into the radiator itself. Is there an adapter of some kind or special lower radiator hose that will work. In other words, my stock loser radiator hose is too big for the corvette hose connection. I'd like to be able to use this pump. Has 0 miles on it.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-30-2007, 08:12 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Water pump hose ?
I don't know about the hose connections, but a Corvette pump is a little longer than a normal short pump. Your belt will not line up right with normal truck pullies and brackets.
Blazer1970 is offline   Reply With Quote
Old 06-30-2007, 02:23 PM   #3
70GMCer
70GMCer's Avatar
Sorry to disagree, but everything lines up perfect......
1997 GMC Sierra Ext
1965 Mustang
Old 06-30-2007, 02:39 PM   #4
1969k10stepside
On mine the radiator fan wouldnt go on,the belts/pulleys didnt line up either...So back to a regular short water pump I went..
1969k10stepside is offline   Reply With Quote
Old 06-30-2007, 02:44 PM   #5
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
There are alot of different hoses out there. Find your best local parts store worker that is competent in useing the books and not the computer cataloging and they should be able to fix you up.
I used to do it ALL the time when I worked at NAPA for the local race track guys as well as myself.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-30-2007, 04:03 PM   #6
cdowns
cdowns's Avatar
you can use the stainless or the braided hoses available from speedway summit jegs pepboys etc they allow you to use different sized adapters on the hose for both ends but theyre alot more expensive than rubber
