Old 06-30-2007, 01:05 PM   #1
1969k10stepside
The Post Your Ground Clearance Specs Thread
Let's give the 4wd section a little more life.Post your ground clearance specs.
My 71 K10 (suppose to have 4" lift).35 inch tires-11 inches under the front and rear diffs.44 front,12 bolt rear.19 inches under the t-case skidplate.
1969k10stepside is offline   Reply With Quote
Old 06-30-2007, 06:16 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: The Post Your Ground Clearance Specs Thread
I too have about 4 inches of lift, and 35's. My clearances are about the same, with 11" under the front and rear diffs, 44 front, 12 bolt rear. and 20" to the bottom of the mighty np 205, no skid plate on mine.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-01-2007, 08:22 AM   #3
vtblazer
vtblazer's Avatar
Front bumper: 29" - stock style
Front Diff: 12" - High pinion Dana
T-case skid plate: 22"
Rock sliders: 34" - no rockers just tubes now
Rear Diff: 11.25" - 14 bolt FF
Gas tank: 30" - custom fuel cell
Rear bumper: 33" - square tube
Tires are 39.5 TSL's - @6psi
Lift is 6" Alcans w/shackles.
Still want more ground clearance, looking @ going 42's.
vtblazer is offline   Reply With Quote
Old 07-01-2007, 11:15 PM   #4
Hardly anyone has a factory skid plate.Not the best to establish a standard.Is this just for kicks?r,are you trying to establish a baseline?
Old 07-01-2007, 11:17 PM   #5
1969k10stepside
Threads just for kicks,yeah,not many would have the 205 skidplates (atleast a stock one)--K5s and Jimmys only..But,I snatched one from a wrecked one
Old 07-02-2007, 12:51 AM   #6
mudmizer
mudmizer's Avatar
front to rear, here ya go. Seems pretty consistant with the rest.
39.5 trxus sts, 2" body and I think 4" lift (stock rear leafs with 4" blocks)
warn bumper bottom = 30"
D44 = 12.75
factory skid spaced off frame 1" = 22"
14 bolt = 11.5
Bottom of ladder bars hanging under axle tube = 14"
Rear bumper home made 6" tube = 32"
frame at door = 27"
bottom of open door = 33"
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 07-17-2007, 07:51 PM   #7
vtblazer
vtblazer's Avatar
All my numbers just changed...
Oh maybe it's from the 42's I just installed.
Old 07-19-2007, 04:46 PM   #8
1969k10stepside
I've got 27 inches under the front bumper of the 69 w/ 6" suspension lift and 33" tires..Now to get some 35s or 37s...
