Old 06-30-2007, 04:42 PM   #1
charlieo
Longer brake hoses ?
I just recieved my Tuff Country 4" lift and was wondering what or who I can call to get some longer rubber brake hoses . I got the re-location kit but thought it would be better to get the longer hoses. Thanx in advance !
charlieo is offline   Reply With Quote
Old 07-01-2007, 04:47 PM   #2
Re: Longer brake hoses ?
I used Inline Tube.You have to approach it as asking them for exactly what you want.Tell them it`s a special application.If they say they only make them to OEM specs ask what do they do for street rods.Measure what length you need.For a 6" lift I got a 24" hose.Tell them what fittings you need including the size and type of seat.I got a jucntion block,too.Also got the pre-bent axle line in stainless.DON`T buy the braided hoses from the lift companies.The front work,but the rear was all wrong,even with adaptors.
Old 07-01-2007, 08:05 PM   #3
charlieo
Great thanx for the reply !
Old 07-01-2007, 10:21 PM   #4
va_tlc
va_tlc's Avatar
charlieo are you sure you need longer hoses? i just finished a 4 inch lift on my truck and didnt even use there relocation bracket, and im pretty sure i have original hoses, i had plenty room left
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 07-02-2007, 01:13 PM   #5
charlieo
I might be jumping the gun here, you might be right I'll check first ! Thanx
Old 07-02-2007, 08:57 PM   #6
Me too.I never changed hoses for 4".But,I did take them out of the frame bracket.
Old 07-06-2007, 03:10 PM   #7
69TowRig
I bought stainless braided hoses from Xtremecrawlers.com as they sell custom Crown hoses. Really nice stuff and the prices are reasonable. They are jacketed and have billet ends.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 07-25-2007, 11:50 PM   #8
customcamper72
i bought brake hoses for a 88 2wd chevy when i installed my 6" lift on my 72,
bolted on ,no problem
customcamper72 is offline   Reply With Quote
Old 07-26-2007, 10:37 AM   #9
Burt4x4
Burt4x4's Avatar
Yup, Napa has longer rubber hoses, I had them pull the ones for my 72 then start pulling different year chevys until they came up with a longer ones that would bolt right up
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
