Old 06-30-2007, 07:46 PM   #1
lou6t4gto
where to get one?
on a 1961 chevy shortbed with an Original Automatic On the Column, I've changed the trans to a th350, and need the Bracket(ARM) that bolts to the transmission shaft that the shift rod from the column moves to change the gears. Does anyone sell such a "critter", or will I have to fabricate one? seems like a common conversion, is one available? thanks for your help.
lou6t4gto is offline   Reply With Quote
Old 06-30-2007, 07:57 PM   #2
mateo1279
mateo1279's Avatar
Re: where to get one?
I had to fab mine... it still needs a little tweaking as it interferes with the body if I try and put it in first only (all the way clockwise)
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 07-01-2007, 12:00 AM   #3
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Check out www.lokar.com they might have what you need. I hope this helps.
Alan's Classic is offline   Reply With Quote
