Old 06-30-2007, 09:29 PM   #1
qksilver
Pix of a 292 with A/C and P/S?
A long story short, been gathering parts to restore my 67 SWB 4X4. It orginally came with a 292 and I am going back to a 292. The truck was built with many options including A/C.
I checked thru the factory assembly manual and found pix of ram style P/S.
Found an old 67 step van with the P/S ram set up.
Have all the A/C stuff but no 292 brackets.
An old truck shop was being sold here and they had me clean out several buses and storage area's out.
Found several boxes marked P/S 292 and A/C 292, they are filled with all sorts of brackets and pulleys.
Sold the 292 engine I was going to use because it was a mexican stamped box.
Can't match up the brackets to the assembly manual pix.
Does anybody have or could take some pix of a 292 with A/C and P/S? Of course I would like it for a 67 ! lol but with some clear Pix I can sort out all the brackets and pulleys.
Thanks,
Steve
SCJKOVACH@AOL.COM
qksilver is offline   Reply With Quote
Old 07-01-2007, 03:23 PM   #2
one9six9
Junior Member
Re: Pix of a 292 with A/C and P/S?
What's the chance that there were some power steering and alternator brackets for a 250 I6 in those parts boxes?
Keith
one9six9 is offline   Reply With Quote
Old 07-01-2007, 04:00 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Here is a 76 292 from over on the 73-87 board, lots of good pix, maybe it'll help:
http://67-72chevytrucks.com/vboard/s...d.php?t=247685
Edit: sorry it is a 77, not 76
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 07-01-2007, 04:12 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
This is 72 & earlier style.
PICKMUP is offline   Reply With Quote
Old 07-01-2007, 04:18 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Ooops! Wrong pics. Those first two pics are 73+. Notice the wider spacing on the belts/pulleys.
Here is 72 & older.
Old 07-01-2007, 07:39 PM   #6
qksilver
Thanks, that helps for the P/S...........
as far as 250 stuff I have a few sets of those(A/C and P/S) It will be quite a while till I can get to them. As any one who has seen my shop, stuff is piled and piled on top in and around everywhere.
Other than a few things I might be selling until I get 2 projects done that are in the shop, I am not even going to try to move stuff.
The 68 wrecker and my 72 burb are first. try me next year on anything else.
the 67 will be after that
Old 07-02-2007, 10:26 PM   #7
qksilver
set on the P/S side any pix of A/C
Thanks,
Steve
Old 07-04-2007, 11:51 PM   #8
qksilver
Ttt
Old 07-05-2007, 12:56 AM   #9
1969k10stepside
Must be a rare truck...dont see many 67 swb 4wds,and hardly any 67s with air conditioning.Add power steering to the equation and there is probably less than 10 trucks like that,that year!
1969k10stepside is offline   Reply With Quote
Old 07-06-2007, 11:07 PM   #10
qksilver
The A/c is factory but the P/S is something I am adding.
If you look in the factory assembly manual it shows P/S on a 4 wheel drive front axle.
I got the truck out of West Virginia complete but rusty. Couldn't bring it straight home, so I parked it at a buddies service station for the week end. What a mistake..........a few things were stripped off of it.
Been trying to piece it back together on a budget. have all the sheet metal except a perfect bed floor. Been working on A/C and P/S brackets and a few small odds and ends.
Was going to keep a V-8 in it, would have been a lot easier.
Old 07-06-2007, 11:11 PM   #11
1969k10stepside
BTW,those rims you sold me back in February are looking good,thanks again and ttt for ya
Old 07-07-2007, 02:46 AM   #12
AuggieStyle
AuggieStyle's Avatar
did i read this correctly? did you say you had 250 l6 a/c brackets...extras?
how much would you want for the a/c brackets?
thanks
auggie
AuggieStyle is offline   Reply With Quote
Old 07-07-2007, 10:42 PM   #13
sakohntr
sakohntr's Avatar
If you need anymore 67 4x4 ps parts i know of one truck that is still complete but it was a smallblock i believe. The ram and all is still in it......
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 07-07-2007, 10:44 PM   #14
sakohntr
sakohntr's Avatar
PICKMUP is completely right about the year brackets. If you use the newer ones they will make contact on the manifold and stat housing before bolting up correctly. Hard to finddddddd
Old 07-09-2007, 08:48 PM   #15
qksilver
those wheels look sweet!
