Old 06-30-2007, 10:02 PM   #1
RM72chevy
RM72chevy's Avatar
Rear Glass Removal
Hey all,
I was wondering what all is entailed to remove the back window off a 72?
I would like to pop the glass out, add window tint the reinstall with molding covering the the area where the tint was cut.
If it's a hassle then I'll try tinting the hard way.
RM72chevy is offline   Reply With Quote
Old 06-30-2007, 11:11 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Rear Glass Removal
I used a peice of string and a flat head screwdriver to get my slider out and cause im cheap (broke) I used the same gasket to put the solid one back in. It was pretty easy and havent had a problem with it.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 06-30-2007, 11:35 PM   #3
BAGGERSOCAL
Active Member
shouldnt be any problem re using the Old rubber as long as it still in good usable shape not old a crusty .
BAGGERSOCAL is offline   Reply With Quote
Old 07-01-2007, 12:46 AM   #4
krue
Designated A-hole!
krue's Avatar
Just be careful and go easy and you should be alright.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-01-2007, 08:39 AM   #5
OJOE
Crew Cut
OJOE's Avatar
about 5 yrs ago i found out the easy way is a gas weed eater by your drive way and small rock.
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
