Old 06-30-2007, 10:44 PM   #1
David Flores
David Flores's Avatar
sandblasted frame
So today I sandblasted most of my 66 frame. Gosh It's nice to see clean metal. Only think I didn't like about it was sweeping up about a 100 pounds on sand so far. I bought the blaster off someone for about 30 bucks and about 300 pounds of sand for 27 bucks.
Question though. Tomorrow I should have the complete frame blasted and cleaned up. Have any of you guys ever used MasterSeries Silver Permanent Rust Sealer Primer Or do you know of any Rust Sealers I could buy locally?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 06-30-2007, 11:21 PM   #2
msgross
msgross's Avatar
Re: sandblasted frame
I used it, my frame is on their website... www.nomorerust.com
I loved the sealer, like the paint. Are you doing a show truck? If not and you are on a budget but want a good result then I say use it. Check out my build thread if you want more pics of it.... Very durable stuff when it's on a blasted piece of metal...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-01-2007, 11:57 AM   #3
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
We only use the Nason (Du Pont) self etching primer part number 491-17 and actvator 441-43. It is economical, and I have yet to spray anything that holds better! It has a 1:1 mix ratio and sprays easy. I follow it up with chassis black, number 422-05, which is very easy to touch up if you get any scratches during re-assembly. Good Luck!!!! Jerry
ClassicAutoResto is offline   Reply With Quote
Old 07-02-2007, 01:40 AM   #4
stepside66
stepside66's Avatar
just go grab a can of por 15 you can have gloss semi or flat black I used it on my truck frame and you can brush it on or spray it with an hvlp gun sprayed thru the gun looks really good it etches into rust and wont chip off unless you are delebrately trying to
stepside66 is offline   Reply With Quote
