Old 06-30-2007, 11:52 PM   #1
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Question 1972 Frame under a 65?????
I've got a 65 c10 SWB that is completly stripped and have a friend of mine that has a 72 C10 SWB that is already powder coated. I just got another 72 C10 LWB frame that has PS and 5 lug front disc brakes. I just finished stripping the junk frame of everything including front suspension crossmember. From all the measurements that I've taken (cab mounts forward) everything is the same except the rear axle is 1.5" wider. It seems that it will be easier to mount the PS on the 72 frame since it came with it. I don't have to use the PS gearbox adapter plate like I would on the 65. Is there anything that I'm missing.
Alan
Alan's Classic is offline   Reply With Quote
Old 06-30-2007, 11:53 PM   #2
1969k10stepside
Re: 1972 Frame under a 65?????
Frame horns are different,thats one thing..
1969k10stepside is offline   Reply With Quote
Old 07-01-2007, 01:21 AM   #3
60ratrod
yes, i do
60ratrod's Avatar
my 60 c10 is sitting on a mid 70's blazer c10 frame. it is possible, but you may have to drill new holes in the cab
60ratrod is offline   Reply With Quote
Old 07-01-2007, 08:11 PM   #4
Alan's Classic
Thanks for the resposes. I answered my own question today. I was able to lay the 72 frame on the 65 and get a better comparision. The rear cab mounts and core support mounts are different. Plus frame horns like someone else had mentioned are different. I guess I will just use the original 65 frame. I've got enough work todo without creating more.
Alan
Old 07-03-2007, 09:24 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
the 1967-68 core support will work and i say drill out the ribbits on both frames and remount the cab mounts
stsalvage is offline   Reply With Quote
