Cab removal advice
I removed the cab of the 68 today. It didn't go great, but I got it done.
Basicly I used a cherry picker through the pass. window and a couple of chains and a engine leveler thing. I used the front cab frame mounts and the front seat mount holes to bolt through and lift from. Basically the cab is very front heavy so that gave me some problems then also the cherry picker was hitting the door and area behind the door. I wasn't too concerned about scratching the 68 cab, but when I go to pull the 72's cab it will be a big concern, so any tips would be great. Oh yeah, I did this with my wifes help.....maybe I should just get a few buddys to help manhandle it. |
Re: Cab removal advice
I think this is the best method for lifting with a portable cherry picker.
http://67-72chevytrucks.com/vboard/s...06#post1941906 I have used this method using a 4x4 and a fabbing a bracket to mount in on top of the lift arm. But if you'll be using one very often I think Kevin's design would be well worth the investment.
72 SWB parts and pieces Oklahoma |
![]() Join Date: Apr 2004
You are lucky to have a GOOD wife to help you!
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I got some beer and a couple of friends...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
