Original 8 bolt white rims
Does any one know or better yet have a picture of the original white 8 bolt rims. I would like to know if they had a hub cap/chrome ring or were they just white with the lugs exposed.
Thanks Joe |
Zappaphile!
Re: Original 8 bolt white rims
They have hub caps (there are bumps to hold them on about an 2 inches or so from the lugs).
I will take some pic's for you later, but looking at 5 of them (on my truck)..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
Thanks, does anyone sell them?
Zappaphile!
Check with your local favorite automobile dismantler. I don't believe anyone is doing reproductions (wouldn't be a big market for them). Most people change them over to 5 lug these days..
its all about the +6 inches
you wouldn't want original anyways. mid to late 80's and into the 90's (including vans) is a better score. You'll get a 16 inch instead of 16.5 inch wheel, looks stock, holds stock hub caps, and holds MUCH cheaper tires.
On these trucks 16s were split rims and 16.5s weren`t.So,as mentioned,you`ll want later rims if you are going for 16s.I buy new ones at wheel and rim places.I have a set in mothballs that I had powdercoated white.
idahospud
Anyone have pictures of a 8 lug 2 wheel drive that they have made look like the rally wheels?
71 cheyenne fleetside shortbed 2003 gmc crewcab duramax SLT 4x4 96 chevy tahoe |
don't quite understand that, there never was an 8 lug rally wheel
you mean the stock steelies with center caps and beaty rings like the rallies?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
here's a couple the first one is a later model 16 inch and the second one is a older model 16.5
Here is a photo of a period 16" wheel, note the gray locking ring.
This is the 16.5" wheel.
#13 |
There were no beauty rings for GM truck wheels until`88 when the factory went to the silver painted steel 16s with beauty rings and center caps that had exposed lugs making them a type of rallye wheel.The centers are held in place by using special duplex lug nuts that have external threads to accept plastic lugs to hold the centerson.These rims have no provision for earlier hub caps.These late-model center caps may be used on flat centered custom or aftermarket steel wheels using these duplex lugs.The factory uses metric.The aftermarket provides 9/16" for use on earlier models.
#14 |
Beauty rings and rally wheels look out of place on 3/4 tons. I have never got use to the generic look of factory wheels without REAL hubcaps since the late eighties.
#15 |
![]() Join Date: Jul 2004
I'll soon have a set of 1971 stock 8 bolt 6.5 x 16.5 wheels after we finsh the conversion to later model 16 inch, I have a set of split rims off another truck and I'll bet neither are hardly worth their weight in steel. If I have to pay to get them dismounted and tire disposal is is going to cost more than they are worth.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#16 |
...until they`re hard to find from everyone tossing them.There will always be a demand for factory original pieces.The fan club may not be huge,but they`re out there.
