Old 07-01-2007, 05:56 PM   #1
Rickey
Rickey's Avatar
Air guage
On my truck there is a guage that has air pressure on it. What is this and could have standard on a 70 swb custom.
Rickey is offline   Reply With Quote
Old 07-01-2007, 06:07 PM   #2
cdowns
cdowns's Avatar
Re: lAir guage
its probally a vaccumme gauge and they were original equipment on big trucks that had airbrakes not available on 1/2 or 3/4ton trucks
Old 07-01-2007, 08:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: lAir guage
actually, the trucks with air brakes had an air guage (pressure) trucks that had normal hyd brakes could get a vac guage.
Either way, it is off a bigger truck, C/40 and up.
If you have a hyd brake problem, or when you crank the engine, there should be a light that come on in the fuel guage that should say brake... if your fuel guage is actually from the bigger truck, it'll say overspeed.
Your oil guage, if from the bigger truck, would be an 80 PSI unit instead of a 60 PSI unit.
Old 07-01-2007, 10:21 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Air guage
Not sure what gauge you are talking about, but if it’s aftermarket it could be a load helping air bag or air shock thing.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-01-2007, 10:37 PM   #5
Rickey
Rickey's Avatar
Re: Air guage
It is a factory gauge and all it has on it is Air Prssure.
