Old 07-01-2007, 07:32 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
sandblasting
well, today i tried out my sandblaster. i blasted about 1/4th of a rally rim, and thought to myself "i didnt picture it comming out this rough-looking on the baremetal".
is that whats normal? also, whats the common method to preparing "viewable" parts for refinishing? i suppose i might need to sand it down quite a bit after im done stripping the rust off, but the shape of the rim is going to make that a total pain in the ass.
tips, stories, etc?
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 07-01-2007, 07:49 PM   #2
projectking
projectking's Avatar
Re: sandblasting
Try blasting with walnut shells, will leave less of a profile on the steel. DuPont calls theirs Starblast, there are other brands out there that are a little cheaper. You can use a filler primer to smooth things out too.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-01-2007, 08:06 PM   #3
RedZ71
Junior Member
RedZ71's Avatar
Re: sandblasting
aight then, i saw that at harbor freight, ill pick some up tomorrow.
Jonathan
1971 LB C10 Custom
Old 07-01-2007, 09:20 PM   #4
woodridge
woodridge's Avatar
Re: sandblasting
What type of media are you using? We use 120 glass beads and it leaves a smooth gray finish.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 07-01-2007, 09:43 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: sandblasting
My experience with walnut shells hasn’t been too good. I supposed it depends on the paint you are trying to remove.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-01-2007, 10:21 PM   #6
RedZ71
Junior Member
RedZ71's Avatar
Re: sandblasting
well im trying to remove a combination of rust and chipped paint.
Jonathan
1971 LB C10 Custom
Old 07-01-2007, 10:29 PM   #7
Sport/Truck
Sierra Grande Club
Re: sandblasting
I don’t think it will remove rust, paint maybe. Have you considered powder coating your wheels?
I don’t think the rough finish is going to hurt your paint outcome if you use a Base Coat/ Clear Coat.
s/t
Old 07-02-2007, 06:39 AM   #8
jaros44sr
jaros44sr's Avatar
Re: sandblasting
How much air pressure are you running???
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-02-2007, 08:02 AM   #9
cdowns
cdowns's Avatar
Re: sandblasting
walnut shells wont do much on rust// i blast rusty rims with sand then just use 80-100grit to cleanup wipe down with thinners and epoxy primer and then the color with great results
Old 07-02-2007, 08:32 AM   #10
jec
jec's Avatar
Re: sandblasting
Sandblasting leaving a rough finish?
I would say that unless the rust has pitted the metal, it is normal and does not matter. I blasted an entire frame, cab, etc. using "play sand". You must wear a mask because regular sand contains silica dust.
The roughness is actually a good thing when it comes to painting. This makes paint and/or primer adhere really well. Also, primers and paint fill in a sandblasted surface and will be mirror smooth.
My 2 cents........................
jec is offline   Reply With Quote
Old 07-02-2007, 09:02 PM   #11
Sport/Truck
Sierra Grande Club
Re: sandblasting
s/t
Old 07-03-2007, 09:48 AM   #12
ScottH
ScottH's Avatar
Re: sandblasting
So what is the best sand to use, and where can you buy it?
Thanks.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
