09-19-2002, 05:17 AM | #1 |
PC Seals?
I have a set of 87 crate motor heads, 1.94 intake valves. The springs are still on the valves so I cant see the seals. What I need to know is if these heads had factory PC seals, or just the o ring type with umbrella's? If they dont have the PC seals, do they have to be machined before they fit? These are the 72 degree center intake bolt angle heads, with center bolt valve covers...
Thanks.....
Patch |
09-19-2002, 08:35 PM | #2 |
seals
TTT
Patch |
09-20-2002, 12:53 AM | #3 |
PATCH ---- I'VE GOT A SET ON THE MOTOR I JUST REBUILT. 87 SWIRL PORT, VORTEC HEADS, 1.94 - 1.50 & THEY WERE MACHINED FOR P.C. SEALS BUT I'M NOT SURE THAT THEY WEREN'T REWORKED ONCE BEFORE I GOT THEM. I'M SURE YOUR GOING TO WANT TO PULL THE VALVES & CHECK EM OUT ANYWAY, AS LONG AS THEY'RE OFF THE MOTOR. I HAD MY VALVES & SEATS REGROUND & MACHINED FOR SCREW IN STUDS & GUIDE PLATES AS LONG AS IT WAS GOING TO THE MACHINE SHOP.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
