Old 07-01-2007, 09:31 PM   #1
Rickey
Rickey's Avatar
surface rust
I lifted my carpet today and there is surface rust in the floorboard. What would be the best to treat this before it becomes a big problem.
thanks rickey
Rickey is offline   Reply With Quote
Old 07-01-2007, 09:37 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: surface rust
Rust bullet.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-01-2007, 09:44 PM   #3
David Flores
David Flores's Avatar
Re: surface rust
Naval jelly works wonders if done right.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 07-01-2007, 09:49 PM   #4
Sport/Truck
Sierra Grande Club
Re: surface rust
That’s debatable, most people here will disagree with the use of naval jelly (and it does nothing for keeping the rust from coming back).
s/t
Old 07-01-2007, 10:03 PM   #5
Rickey
Rickey's Avatar
Re: surface rust
Should I sandblast the area and prime the area. I just want to stay on top of it before I have to replace the floor.
Old 07-01-2007, 10:07 PM   #6
Sport/Truck
Sierra Grande Club
Re: surface rust
When using RB you just need to scuff the area to remove anything that is loose, then brush it on. It’s that easy.
s/t
Old 07-01-2007, 10:32 PM   #7
Rickey
Rickey's Avatar
Re: surface rust
Where do you get RB. thanks for the tip.
Old 07-02-2007, 09:10 PM   #8
Sport/Truck
Sierra Grande Club
Re: surface rust
here you go Rust Bullet
s/t
Old 07-02-2007, 10:04 PM   #9
killer71
killer71's Avatar
Re: surface rust
this is what i've used in the past many times. It's simple to apply and as an added bonus it WORKS. You can get it at any hardware store. The only color i've used is the black. Hope this helps. http://www.rustoleum.com/CBGProduct.asp?pid=159
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-02-2007, 10:05 PM   #10
Rickey
Rickey's Avatar
Re: surface rust
Thanks for your help.
