Old 07-02-2007, 10:30 AM   #1
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
AC fittings`134a
The adaptor fittings in conversion kit do not fit the '72.
Any one know where I can get the correct adaptors for the conversion?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 07-02-2007, 08:37 PM   #2
JimKshortstep4x4
Re: AC fittings`134a
I got my adapter from the local parts store. They carry a selection of adapters. (It is an Auto Value which is a national chain). I would think other parts suppliers would have them, also.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-02-2007, 08:44 PM   #3
jkade
jkade's Avatar
Mine came in a 134 conversion kit and they worked fine.
jkade is offline   Reply With Quote
Old 07-02-2007, 08:45 PM   #4
eedgell
It's the air up here
eedgell's Avatar
All of the ones I have converted have been the kit from wal-mart. Worked every time.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-03-2007, 01:14 PM   #5
DennyB
DennyB's Avatar
Hmm, Thats odd. The kit I got has three odd (read metric) fittings.
At this point I'll just use the fittings on the gauges. I realized the standard fittings on the gauges with all the adaptors removed screw right on .
That thread is what? 3/8 NC? 5/16 NC?
I.M.O.M,W,J&C
Patriot Guard Rider
Old 07-03-2007, 02:48 PM   #6
CST*TEN in Katy
I believe the fittings are 1/4" flare tubing. I did my R-134 charge last week, I put the adapter fitting on the center port of my gauges, that allowed me to use the R-134 cans through my old gauges and my stock R-12 ports.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
Old 07-03-2007, 03:05 PM   #7
Nachos82
DennyB, did you buy the kit from WalMart? I bought a conversion kit there a while back, and it came with two of the same wrong size/style fitting. I took it back and got anouther one and it worked fine. Not sure how that could happen, but it was a bit strange.
Nachos82 is offline   Reply With Quote
Old 07-03-2007, 03:39 PM   #8
DennyB
DennyB's Avatar
That must be the size. This is also what I'm doing (using stock R-12 ports).
No, I got them at a parts store a few years ago. The fittings in these are 3 types and sizes. The directions say they fit down to 1978.
I'm not an AC guru and have no idea when all the changes took place.
What I didn't realize before this post was the fittings fit my hoses w/o the adapters, I can evacuate and fill through the center hose, so its a simple solution. Just as CST*TEN above has done.
I.M.O.M,W,J&C
Patriot Guard Rider
