Old 07-02-2007, 12:33 PM   #1
FormerMember
2wd to 4wd 70 Chevy C30 frame
Ok, I've done a fair bit of research.
I have access to two 4wd frames:
One is a 72 K20... the other is a 91 K5.
Are the front spring hangers any different between the two?
I plan to use a set of 4wd hangers on the C30 chassis: the question is, which ones? 91 K5 or 72 K20?
FormerMember is offline   Reply With Quote
Old 07-02-2007, 01:17 PM   #2
jimmydean
jimmydean's Avatar
Re: 2wd to 4wd 70 Chevy C30 frame
The K5 is IFS isn't it? If so, then I would say the lack of front hangers would be a bit different than the '72.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-02-2007, 01:18 PM   #3
FormerMember
K5 stayed solid front until 91.
The K5 is a leaf sprung suspension front and rear.
Old 07-02-2007, 05:21 PM   #4
Blazer1970
Blazer1970's Avatar
The '91 probably has wider springs than the '71, otherwise the front hangers will be very similar. The '91 also uses longer front springs so the rear hanger and shackle on the front spring will be farther back than on the '71.
Blazer1970 is offline   Reply With Quote
Old 07-03-2007, 08:13 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
Did you go get the C30 frame yet ????
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-03-2007, 08:58 AM   #6
FormerMember
Heh, nope
Old 07-04-2007, 01:33 PM   #7
FormerMember
I decided to go with one of these:
This allows me to run a longer spring that will provide a better ride with 4" of lift.
Old 07-04-2007, 03:09 PM   #8
eedgell
It's the air up here
eedgell's Avatar
Cool! where did you get that? What is it called, make mod.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-04-2007, 04:59 PM   #9
FormerMember
http://diy4x.com/suspension.htm
FGB52 = First Gen Beyond 52's
It's easier than doing it myself or converting K20 brackets to fit the 1 ton frame.
a 52" spring's going to be a better way to go on this rig.
Where this is a 72, is has the same width springs. Been doing the comparison...
71 and earlier springs are a half inch narrower, that I can tell?
Old 07-05-2007, 09:49 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
That's an impressive spring hanger!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-05-2007, 10:01 AM   #11
1969k10stepside
1969k10stepside is offline   Reply With Quote
