07-02-2007, 09:07 PM | #1 |
urban fourwheelin
****Red72Blazer**** rust repair thread
Well the time has come to save this old girl. I've owned her about seven years and used her well. She's been a daily driver, used her for many a road trip to Eastern Washington. I've done a lot of repair to her mechanicals, but she has slowly deteriorated over the last 7 years. Something must be done...
I guess I'm just looking for encouragement, advice...talk me out of it.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
07-02-2007, 09:11 PM | #2 |
urban fourwheelin
Re: ****Red72Blazer**** rust repair thread
at least the rocker boxes are okay.
07-02-2007, 09:11 PM | #3 |
Can't wait to retire!!
You can do it!!!
And you know all of us will help as much as we can!
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
07-02-2007, 09:12 PM | #4 |
urban fourwheelin
So where can I get the highest quality replacement panels? Where should I start? I have access to welding equipment, I can Kinda weld, I took metal shop in highschool. My Boss is a trained welder/bodyman But he's only ever worked on Land Rovers. I want to start cutting this weekend
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 07-02-2007 at 11:40 PM. |
07-03-2007, 12:29 AM | #5 |
SKINNY TIRES RULE!
Call Wes about replacement panels. He'll know which ones are best. Don't buy from LMC or The Truck Shop for quality panels. He might have at least some of the parts in stock so you can get started this weekend. If I had any clue how to do the those repairs, I'd help ya but that is way, way beyond my knowledge base.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-03-2007, 12:46 AM | #6 |
Dude, just go for it! In my opinion the 1st. gen blazer/jimmy's are as good as it gets! Getting ready to take on my 1970 blazer rebuild soon, just doing research now and stocking up on parts as money allows. I have had this k5 since 1981, and will never consider getting rid of it! Am looking at rust issues also, but where theres a will theres a way! Mine has gone from stock, to 4" lift, w/35", to 8" lift, w/39.5 swampers. Never say never bro!
07-03-2007, 12:58 AM | #7 |
GMCDAC
Hey Red72Blazer,
All these vendors here probably have the panels you need, but you should have your new panels before you hack out the problem areas. The little experience I have at that stuff, it seemed easier to be able to find a dimension to cut the new panel to lay it over the bad surface,mark it then cut the bad stuff out. That is an extremely simplified way to look at it tho. The sheetmetal Guru's here in the Blazer Jimmy forum will be most informative. Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! Last edited by 70gmcjimmy; 07-03-2007 at 12:59 AM. |
07-03-2007, 06:02 AM | #8 |
I was wondering when you were going to get started on it!! Are the 'A' and 'B' posts in good shape? That is where I had problems...
Post up lots of pics. of your progress. Have fun, enjoy the ride. We're here to help. J. PS, don't forget the zinc primer.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-03-2007 at 06:24 AM. |
07-03-2007, 07:07 AM | #9 |
RUST~~~~~~RUST~~~~~Son, that ain't rust!!! Obviously you've never been east of the Mississippi. Around here we call that light surface oxidation!!!!
Before you start cutting, you might want to have the panels in hand to see what is available and what isn't. Blazers have some unique sections like the B pillars that don't have aftermarket sections available. If you pull the hardtop and start cutting~~~you could wind up with two major problems~~the front and the back falling to the ground! hehehehe Anything in front of the firewall is common to trucks. Windshield frame is a PITA so be aware of that. The cab (where the bucket seats go) is pretty much common to trucks and complete large sections are available there. The rear floor, rear quarters, are unique but can be "created" using truck stuff. You are fortunate in that there are 2 Board Vendors right near by who are excellent in their knowledge, experience and carry most STUFF you will need. I would start by visiting them for advice---if possible DRIVE it over and let them go through it with you. Take notes. Use a magic marker to outline areas for cutting. Buy the best quality you can---it always pays in the long run. Just keep in mind that a BLazer is not a tri-five chevy----you can easily put way too much money and time into one and never recover the investment. So decide what you want the end result to be, have a budget and keep to it, then let-er-rip~~~. Huck |
07-03-2007, 11:22 AM | #10 |
SKINNY TIRES RULE!
Good call on taking the truck with you to buy the parts!
07-03-2007, 11:50 AM | #11 |
Post Whore
Huck has great advice. It looks like a daunting task so take your time and do the project in stages so you're focusing in on one small area at a time so you don't get overwhelmed. Good luck!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-03-2007, 05:19 PM | #12 |
Gotta agree with Huck on his thoughts. All the areas look strait forward and aren't that bad but.......
The 'B' post, lower forward rear quarter, rear of rocker box mount, rear floor panel and step up area, have alot of layers in that one area. To quote Rusty Parts, " it's like peeling an onion, gotta get rid of a whole lotta bad layers before you get to the good stuff " and that area is tuff Your going to have to fab up some stuff yourself, but I think I just heard of the step up being made, so that could save you some time.... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-03-2007 at 05:22 PM. |
07-03-2007, 05:58 PM | #13 |
Cochino_Racing_909
i bought my rockers from brothers are they ok?
07-03-2007, 07:51 PM | #14 |
urban fourwheelin
Thanks for the encouragement guy's. I was hoping to start cutting on the 4th. Probably not gonna happen . Looks like I got a little ahead of myself. I called Wes, gonna go down there this weekend. Hopefully, I'll start cutting this weekend. I
Couple questions. 1. I am planing on leaving the top on so the body won't flex as much. But I am wondering if I should reinforce the door openings too before cutting? Also, I want to replace the body mounts and get all the door measurements correct. Should this be done before or after the rust repair? I've already got to much into it...but she will never be for sale so it doesn't matter. Thanks for the advice Huck. You got me on the right track.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 07-03-2007 at 08:47 PM. |
07-04-2007, 01:16 AM | #15 |
SKINNY TIRES RULE!
Yes, they have quality parts and service. They are also a board vendor/member.
07-04-2007, 07:43 AM | #16 |
The LuvShack Garage
That chit will buff right out, that ain't rusty
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-04-2007, 07:49 AM | #17 |
That's a fact!!!!!
07-04-2007, 08:08 AM | #18 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-16-2007, 08:50 PM | #19 |
urban fourwheelin
Made a little progress. stripped some paint, Decided to install new body mounts before fixing the rust. Hopefully I will be doing that this weekend. I discovered some more rust in the rear bed area. Big surprise, looks like I'll need some patches. Can i remove the bed floor without removing the bed sides? I'll have some pictures soon of the new rust.
07-16-2007, 09:32 PM | #20 |
Looking forward to your pics/progress. I have similar rust issues on my 72 Jimmy. I was planning on having someone else repair mine but I might attempt mine with the right pics (hint hint).
07-16-2007, 09:36 PM | #21 |
Project Junkie! Fishing Poor!!
You will have to remove the bed sides before you can remove the bed floor. The sides are both welded and bolted to the bed bottom.
We also have probably everything you need to fix the floors, rockers, rocker boxes, rocker box end caps, rocker box supports, rear floor supports, rocker back plates, floor sections, "A" pillar patches, "B" pillar patches.. and Etc. We are here in Olympia, WA. Let me know if we can help you. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
03-20-2009, 07:30 PM | #22 |
urban fourwheelin
My oh my where does the time go? It's been a year and a half and I have accomplished nothing on this project. guess two moves, starting a business, and other projects have gotten in the way.Also on 7/16/2007 One of the brake lines rusted through and started leaking. So basically I parked it and put it on the back burner. In the mean time I built this
and my grandfather gave me this and now I have a new 600sqft garage that I think I can squeeze the blazer in for some long over due repair so hopefully you guys can expect some progress and pictures coming soon of the tear down this weekend.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 03-20-2009 at 07:33 PM. |
03-25-2009, 07:19 PM | #23 |
Don't worry, when the weather gets nice, you'll start itching to be driving around in a topless Blazer. Then, you'll start working on it again . BTW are you in the Rover business? I noticed all the old school Rovers in one of your pics.
03-27-2009, 11:55 AM | #24 |
Wide n'Low
Red72Blazer,
For even more encouragement, and maybe even a few parts you need, be sure to make the Monroe swap meet next month.. Lot's of us will be hanging out there, and we can chat about all the work (no no fun..) we are going to have working on our Blazers. I am right there with you on mine, just got some goodies from Wes and just getting started on my restoration. Best of luck! Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
03-27-2009, 12:55 PM | #25 |
SKINNY TIRES RULE!
Ah, the Monroe Swap Meet. I've gotta get that on my calendar!
