![]() Join Date: Feb 2001
Best air Cleaner?
Just what it says. What should we be using? I have a K & N.
its all about the +6 inches
Re: Best air Cleaner?
our oil lab at the shop swears K&N is only good for stopping bricks and birds.
They say a good paper filter is the best you can do for your engine *for normal operating conditions* |
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
There's nothing wrong with a properly maintained K&N
You're grille is supposed to stop the bricks and birds. |
#5 | |
hahahahahahahahahahahahahahaha!!!!!!!!!!!!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
well, im not really sure how an air filter could give you more power without letting in more air.....and if it lets in more air it has to let dirt and dust in also. My uncle works at a f*rd dealership and he says he has seen more "dusted" engines beyond repair with k&n filters that you could imagine....i dont know, id rather sacrafice the few horses and be safe. just my 2cents i guess
#7 | |
yea, your prolly rite. its funny how farm kids down here put K&N on their cowboy caddy diesel trucks and live down 10 miles of gravel roads.....ive seen many brand new diesels get screwed up like that.
#9 | |
Also the oil that you put in the filter gets sucked into the engine and can mess up sensors on the late model vehicles. |
STOLEN
![]() Join Date: Jun 2006
Interesting info most never consider.
In Search Of |
I can't imagine that they are all that bad if you are driving with them under normal street conditions. To be honest, I didn't notice a power difference when I put mine on. But since I paid the money for it, and I don't really get off paved roads, I'm gonna use it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
this is one of those questions like the ford vs chevy and bigblock vs small block deal, just run what you want kinda thing, i personally run a paper filter on mine
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#13 | |
#14 |
odds are you'll never lose an engine to a fram oil filter... but they are still the least filtering filter on the market.
#15 |
So what I am taking from all this is if I don't drive in dusty conditions with my K&N I should be alright as long as I keep it maintained?
#16 |
IMO, Yes
#17 |
LOL I have always cleaned it in the kitchen sink.
#18 |
Here, check this out: http://www.bobistheoilguy.com/airfilter/airtest3.htm
#19 |
Post Whore
![]() Join Date: Feb 2000
I ran a K&N on my 95 GMC Yukon and it sure got the TBI dirty quickly. Maybe I was putting too much oil on the filter, I don't know. I do know that one day I had the filter out and held it up towards the sun and I was amazed at how many holes I was seeing at the base of the pleats. The filter had about 120,000 miles on it but I always cleaned it as directed. I took the filter off that day and went back to a regular style filter.
Now, having said that, I'm still running K&N's on my 69's 454 and my 70's 400 sbc. I will continue to inspect them and just might go ahead and replace them rather than continue running them due to the problem with the one I had on my 95.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#20 |
my oil bath air cleaner works pretty well here in texas..ha ha ha
#21 |
Fabricate till you "puke"
At 140 mph, my old longhorn "sucked up" Big Bird through the K&N....that little Chev stroker just hiccoped a couple times.......then all you could see was feathers out the tail pipes! LOL! IMO, the K&N is not to be used in a gravel pit dump truck, but in the proper "street app", is not a bad filter. If you are worried, add the foam prefilter to the outside, that the roundy pounders run on that K&N
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 07-03-2007 at 06:32 PM. |
#22 |
GEARHEAD
I will buy anyone that wants to get rid of there K&N filter, two stock replacement paper filters WIX, FRAM, AC/DELCO you chose for their K&N in return. As long as you have the original reciept they have a million mile warranty if they are maintained properly.
Holes are not good and if a K&N filter has them I agree replace but, when properly maintained they will keep out the dust and grit, if you drive in dusty conditions a pre-filter is a GR8 idea as crazy longhorn stated. BTW the kitchen sink might just piss the wife off, MUDDER. RJ22... ![]() |
#23 |
#24 | |
Junior Member
I've heard of bird strike tests on jet engines, but never SBC's. You should write a paper. Then write one explaining how to get an old Chevy truck to go 140 mph. Mine rarely sees the high side of 60.
#25 |
Part of getting decent filtering out of a K&N or other reusable filter is doing the maintenance correctly. That is to say, clean it when it's dirty and oil it with the proper amount of oil. I do know that on the Tbird board I'm active on, K&Ns are usually blamed for dirty MAF sensors and poor running cars because of it.
Josh '70 Custom Camper / 20 |
