Old 07-02-2007, 11:20 PM   #1
jackyl9999
jackyl9999's Avatar
Power steering question
Hey everyone. I recently bought a serpentine belt setup off a 88 s-10 with a 4.3. It came with the power steering pump. I dont have any pics of it. But I was wondering if it would work on my 70 model gmc? I know I would have to put some fittings on it.
Thanks for any feedback
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 07-02-2007, 11:37 PM   #2
streetstar
streetstar's Avatar
Re: Power steering question
I have a similar question so i figured i'd post it here too ---- the girlfriend destroyed my 88 S-10 DD with a 2.8 V-6 (not the 4.3)--- would any of the serpentine parts or other accessories work on a V-8?
And would the overdrive transmission in this truck work with a mild V8?
streetstar is offline   Reply With Quote
Old 07-03-2007, 12:02 AM   #3
krue
Designated A-hole!
krue's Avatar
Streetstar you're out of luck, they're not the same front or back.
Jackyl you should be able to use it. Check with Palf70step on the fitting issue, he had an easy fix, but I don't remember what it was.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-03-2007, 12:08 AM   #4
brak
brak's Avatar
most likely the issue will be that the new pump will have metric threads, whereas the old pressure hose will have standard threads. You can get an adapter.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 07-03-2007, 12:12 AM   #5
krue
Designated A-hole!
krue's Avatar
What I did was cut the high pressure line at the metal tubing and used a compression type union to join the line from the trucks steering head to the pump line.
www.daveramsey.com
Old 07-03-2007, 09:52 AM   #6
jackyl9999
jackyl9999's Avatar
Allright I'll give it a try. thanks everyone!
1990 K1500 Daily
