Old 07-03-2007, 02:39 PM   #1
85_SWB
85_SWB's Avatar
Tire size ?
I want to get some new tires.
im lookin for a lower profile front and a fat rear.
i have 15x8 wheels
i was thinking 235/50 in front and 275/60 in back
can i go bigger in the back?
i have a 3/5 drop
1985 C10 SWB- *Project*
85_SWB is offline   Reply With Quote
Old 07-03-2007, 02:51 PM   #2
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Re: Tire size ?
I have 255/60/15 in the front and 275/60/15 in the back, it looks very good I think:
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 07-03-2007, 02:58 PM   #3
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Tire size ?
you should be able to run 295s in the rear, sidewall will bulge a little but you ain't cornering with the rear tires so flex should not be significant. for the front 235 is way too narrow, I'd go for 255/60 there as that'll put the 8" wheel right in the middle of the tire manufacturer's recommendations so tread deformation and sidewall flex will be minimal and handling will be better.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 07-03-2007, 03:32 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Tire size ?
I suspect that a 235/50 will be much too short for the front. It won't fill the fenderwell at all.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-03-2007, 05:18 PM   #5
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: Tire size ?
I had 225/60's and 295/50's on my ol' Blue truck......
My orange truck has 235/60's and 275/60's.....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 07-03-2007, 10:09 PM   #6
benoit454
Chris
benoit454's Avatar
Re: Tire size ?
We just bought a set of 255/60's and put them on the new 15x8 wheels, they'd fill the wells nice with a drop...
I've personally seen a set of 275/60's on 8's and they looked awesome, very nice and fat.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-04-2007, 12:43 AM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Tire size ?
275/50/15's on a 9" rim
Malo83 is offline   Reply With Quote
Old 07-04-2007, 12:46 AM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Tire size ?
She's looking nice benoit454
Old 07-04-2007, 01:55 AM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: Tire size ?
I'm running BF.T/A's 295 50x15 out back and 275 50x15 up front. I was running 305's out back but BF. does not offer this size anymore.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 07-04-2007, 11:40 PM   #10
85_SWB
85_SWB's Avatar
Re: Tire size ?
esll.
how wide are your wheels
after thinking about it i do want to fill the fender well some
heres what it looks like with 205/70 on front and 235/75 on back
Old 07-04-2007, 11:47 PM   #11
85_SWB
85_SWB's Avatar
Re: Tire size ?
and also i want the rear tire taller in the front because after my drop the rear ended up appearing lower with the same size tires all around. So i want a shorter tire in the front.
Old 07-05-2007, 12:00 AM   #12
ocbaud
Garage Queen Material
Re: Tire size ?
if anyone can find me a 27" tall drag radial for 17's, i would LOVE YOU
ocbaud is offline   Reply With Quote
Old 07-05-2007, 02:22 AM   #13
EAST SIDE LOW LIFE
Re: Tire size ?
Ok here's the thing. I was already running BFG T/A's and the fronts are as new but the rears were needing to be replaced. I tried to get a set of BFG T/A's 305-50x15's for the rear as this is what I was running but BFG. no longer makes them. 295's are as wide as you can go in a 50's series tire. So I thought I would go big & tall as you are doing. So 60's rear & 50's front was my idea. Well in a 60 series I was informed 275's were the biggest available. So I chose to go the 50 series all around as this gave me 295's out back with 275 up front. 295's are 10cm less width then a 305 which is about the width of your baby finger. Quite frankly you can't tell.
As far as rim size 15x8 front and 15x10 rear.
esll.
Old 07-05-2007, 09:50 AM   #14
cochino12
It followed me home?
cochino12's Avatar
Re: Tire size ?
I was told bfg stoppped making the 295 also?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-05-2007, 10:25 AM   #15
streetstar
streetstar's Avatar
Re: Tire size ?
BFG makes a Radial TA in 285/70 - 15
From the side it looks like a pro street tire and it was designed for street rods initially
Any good tire shop (or even Wally World) can get them
streetstar is offline   Reply With Quote
Old 07-05-2007, 12:55 PM   #16
benoit454
Chris
benoit454's Avatar
Re: Tire size ?
Thanks malo83, but she needs dropped like yours and 85's I was thinking the exact same drop a 3/5 or just like 1-1/2 to 2 coils cut off the front and a flip kit out back. Just not sure about the stiffer ride in front, roads suck here and are rough.
If you want taller and wider in back I'd do like a 275 60 in the back, and then do like a 235 or so 60 in front.
Or as you said like a 295 or 275 60 or 50 in back and then if you do say 60 in back do 50 in front, but it's not gonna make much difference really. The 255/60's I got are a tad shorter then the 235/75's I had on it.
Chris
GIT R DONE!!!!!!
Old 07-05-2007, 11:33 PM   #17
85_SWB
85_SWB's Avatar
Re: Tire size ?
I think im gonna go with the 235/60f 275/60r
69BBsuburban: Do you have any more pics like a straight side shot for from the rear?
Or does anyone for that matter?
Old 07-05-2007, 11:49 PM   #18
85_SWB
85_SWB's Avatar
Re: Tire size ?
Do you guys think i could fit a 285/70?
Old 07-05-2007, 11:51 PM   #19
Rc 415
Rc 415's Avatar
Re: Tire size ?
Old 07-06-2007, 12:52 AM   #20
streetstar
streetstar's Avatar
Re: Tire size ?
They look sweet with the right suspension setup -- the rear end has to be low to keep it from looking like a stinkbug, ------ i forgot what size wheels you were going to run, but on 10's, it should still tuck tire. Your truck is low enough to run those tires now, but on a stock truck, they look pretty tall. The taller tire is mainly to give it a drag-type look
The BFG's last a long time and are pretty close in height and width to a M/T 29 x 12.50 Sportsman
Old 07-06-2007, 07:25 AM   #21
85_SWB
85_SWB's Avatar
Re: Tire size ?
im running 8" wide wheels
Old 07-06-2007, 07:41 AM   #22
68Stepbed
68Stepbed's Avatar
Re: Tire size ?
I personally like some beef under the massive wheel wells of these trucks. Here is the truck Bigarmzz used to own. It has 235/75/15 front and 285/70/15 rear with a 5/7 drop.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-06-2007, 12:03 PM   #23
benoit454
Chris
benoit454's Avatar
Re: Tire size ?
If he could run em with that drop you'd have no problem.
IMo too tall of a tire though, love the race car big and little look, but that tires raises the back up pretty good looks like to me. Not body to tire, but road to frame, around here with bad roads that's a good thing.
I'd do a 285-295 and do a 50 or 60 if it was me, that way it aint real tall. Still looks awesome though.
I love the 275's when I seen some 175/60's in person I fell in love with them, also seen a set of 295/50's in person and man they are fat, love them too, sidewall looked way to small to me though at least for a fullsize truck, they seemed to me to look best maybe on a car or s-10. A 60 series in a 295 would be nice.
I think your choice would be a good one though 235's and 275's.
Chris
GIT R DONE!!!!!!
Old 07-06-2007, 01:44 PM   #24
68Stepbed
68Stepbed's Avatar
Re: Tire size ?
I personally think the 235/60's will look too small on your truck. If you want to run 60's, I would run a 275/60 rear and either a 245/60 or 255/60 front. A 225/70 looks good with a 275/60 rear also.
ocbaud, M&H Racemaster makes a 28" 275/50/17 drag radial. Look in Jeg's. Do you LOVE ME?
Here is a pic of my truck with 275/60 and 255/60's but it's not lowered.
Matt
Old 07-06-2007, 01:52 PM   #25
grinch4om
dang its hot
grinch4om's Avatar
Re: Tire size ?
235-70 on frt, 255-70 Rr frt on 7" ralleys, rear 8" 6/8 drop
grinch4om is offline   Reply With Quote
