![]() Join Date: Sep 2003
Rear driveshaft question
I'm down to the final part needed to get the Sierra Grande on the road, and I'm finding great difficulty locating it......
I put in a 700R4/208 and need a rear ds. I brought the '84 blazer shaft (trans/transfer case donor) and the original 72 shaft to the local driveline place, and they said they couldn't get a 4-1/2" yoke to weld on for the slip yoke. The local custom weld shop doesn't want to tackle the job either. I'm looking for an 81-87 driveshaft, but have not been able to find one. What changed in 1988? I'm guessing the spline count? Can I use a 1988+ ds and swap the yoke? I know it would need to be shortened, but I'm interested in the yoke end working first. I've got a yoke and a driveshaft, but not the piece I need. Any info on the driveshaft changes over the years would be most welcome. I've tried all the local boneyards and nobody has a 3/4 ton ds that would work (81-87). I have also searched the web for a good on-line parts locator, but have yet to find a decent one. Again, any help would be appreciated! Thank you, Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
Dave's not here, man
Re: Rear driveshaft question
Here's a bump for you; wish I could help.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
paul does it have to be from a 3/4 ton?i have a diesel blazer and am picking up a diesel sub in the morning. but both are 1/2 tons
common sense isn't so common anymore Last edited by wibilly; 07-04-2007 at 01:42 AM. |
I would prefer a 3/4 ton shaft, but post pics of what you have. I really need to drive this thing!!
what rear end are you using and what isthe total length you need? my shafts are all in so i have no pics. but with mesurements i could maby find you somthing that will work. i'm thinking of doing the same with my k 20 swb but i wanna stick with my 205 if possable
common sense isn't so common anymore |
