chevy truck fan
all,
the parts listed below are all from my 1972 chevy 2wd, swb, 350 v8, stock pickup, green in color. prices do not include shipping. pics are available of all items, please respond in thread for pics. thank you... Here is a list of the parts that I have: 1)Stock ’72 dr. side fender (green) some surface rust. $50+ship. 2)Stock ’72 Dr. side inner fender well, surface rust & rust at corner. $25+ship. 3)Stock ’72 fan shroud has small cut out at bottom of shroud & dr. side tab is cut. $30+ship. 4)Stock ’72 gas tank great driver shape (with all mounting h/w). $40 (+ship. If option) revised: now $25 5)Stock ’72 engine harness in good shape (no cuts). $35+ship. 6)Stock ’72 dash harness in really good shape. $50+ship. 7)Fender badges “custom 10” with “deluxe” both sides, very good cond. $25+ship. 8)Stock ’72 vacuum canister & bracket (powder coated) $30+ship. 9)Stock ’72 1/2 ton drum assy. (from back. Plate & out, include. Back. Plate) $40+ship. 10)Stock ’72 lower body trim (missing dr. side most front piece & pass. Side most rear piece), driver shape. $75+ship. 11)Stock ’72 alternator & bracket $30=ship. 12)Stock ’72 rear taillight trim brackets, good driver shape $20=ship. 13)Stock ’72 headlight trim rings, good driver shape. $15+ship. 14)Stock ’72 bench seat. Very good pass. Rough driver’s side. (green). the lower body trim is in a previous post: http://67-72chevytrucks.com/vboard/s...d.php?t=248028 the alternator & bracket as well: http://67-72chevytrucks.com/vboard/s...d.php?t=239892 i hope i did all this right! thanks for looking!!! rodstored-72
Fix It Till It's Broke
Re: Parts For Sale-'72 Chevy
Engine harness as in wiring harness? how much for the bench?
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet Last edited by semperfidoordie; 07-03-2007 at 09:13 PM. Reason: forgot something |
chevy truck fan
semperfi,,
the (engine)wiring harness is the harness from the firewall out to the lights & etc. also the dash harness is the wiring harness with the fuse block & goes to the dash stuff & column. hope this helps. thanks!! rodstored-72 |
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
what could I get both harness' for shipped to 72022? very interested in both.
a green one with some stuff done to it.... |
chevy truck fan
havinsomefun,
i will send them to you for $90 for both. if still interested please pm me. thanks!! rodstored-72 |
chevy truck fan
somefun,
here are the pics of the wiring harnesses. thanks! ..... rodstored-72 |
chevy truck fan
bump.. for the weekend...
Would you be willing to seperate the sender from the tank? Assuming it's all o.k. and the sock isn't torn how much to 80550?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 07-06-2007 at 04:49 PM. |
chevy truck fan
powell,
i will try to take a pic of the sender out of the tank this afternoon. i think that it should be good because the tank was working fine when i pulled it. yes i will seperate. if after the pics you are still interested than i will check on shipping. i am not sure how big the sender is to tell what i would be able to ship it in. just guessing i would think that shipping would be around $10-15 ???. i have no idea what the sender by itself would be worth?? would you be willing to give me a fair idea?? thanks!! rodstored-72 |
Sounds good, they're around $40-50 new depending on where your looking. I'll shoot you an offer after you check on shipping so I can make it worth your while.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
chevy truck fan
powell,
here are pics of the sending unit. i checked on line with dhl & for a 3lbs package it was roughly $8 from 85224 - 80550. if still interested please let me know.... thanks!!! rodstored-72 |
It looks good other than the sock that's pretty hammered. How's $23 shipped sound, $8 for shipping and $15 for the part?
#13 |
chevy truck fan
powell,
i am guessing that the sock is the "filter" part at the end of the sender?? the sender & everything still worked when pulled. i would be willing to go with an even$25 shipped?? and i promise that it will be in a good package (lol...) thanks!! rodstored-72 |
#14 |
Works for me, is Paypal o.k.?
#15 |
chevy truck fan
powell,
sold!!! i will box it up tonight. paypal is fine. i will send a pm with my info as well. let me know if all is good. thanks again!!! rodstored-72 |
#16 |
Sending payment...
#17 |
chevy truck fan
the sending unit from the gas tank is now sold!
the good news is that everything else is still up for grabs! so don't everyone jump at once!! (lol) the gas tank now is down to $25 for you guys... thanks!! rodstored-72 |
#18 |
chevy truck fan
well i meant to do this on friday, but my pesky work got in the way!..
bring to the front for the weekend (ttt) thanks!! |
#19 |
Can I get a pic of the fan shroud and priced shipped to 73135.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6
#20 |
chevy truck fan
st1x10,
here are the pics of the shroud & fan. the fan is off of a '92 p/u. the shroud again is for a stock 350 v8. thanks! also it looks like shipping would be in the area of $25-30 using 73135 zip & package wt. of around 10-15lbs. (that is dhl ground ship.) let me know what you think.. rodstored-72
#21 |
I will have to pass for now. Thanks thou.
#22 |
chevy truck fan
once again for the weekend rush!
ttt .... |
#23 | |
The Older Generation
Tell Powell72 that his local Chevy dealer can get the sending unit filter. The part number is 5651705.... LockDoc
#24 |
Thanks for the info, I didn't think it came off.
#25 |
Yep, just slides right off....
LockDoc
| Bookmarks |
