Old 07-03-2007, 10:15 PM   #1
jkade
jkade's Avatar
Bought truck, I have several questions need answered.
Here is the link to the pics of the truck http://67-72chevytrucks.com/vboard/s...d.php?t=247690
Here are the questions:
1. The truck has idiot lights and I want to use the guage cluster out of my 72 blazer. I know GMC pauls has the plug diagrams, so I reuse the same plug in the 67 and just pull the terminals and replace them in the slots that gmc paul has listed? I know I will need a oil pressure line and replace the water temp sender, what else will I need to do?
2. I am going to put the disc setup and spindles off my blazer on the truck. Will I need a new master cylinder and porp. valve? The truck has a booster, can I reuse it? I think I may just swap the rear end out of the blazer and use it under the truck so I wont have to worry about having axles redrilled and it already has rear disc also. I was thinking of using the porp. valve that ccp sells that is for disc/disc.
I think I am going to put the 20" ttII's on it also and get some different wheels for the blazer.
jkade is offline   Reply With Quote
Old 07-03-2007, 11:44 PM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Bought truck, I have several questions need answered.
C'mon man dont start partin out the Blazer..lol
bagged74 is offline   Reply With Quote
Old 07-09-2007, 09:02 PM   #3
jkade
jkade's Avatar
I know it is what it sounds like . I figured it would be cheaper on me right now to use parts from it. The rear end in the blazer has new 3:73's and a eaton posi and I wish I would have went with a trutrac and 4:11's since I am going with a overdrive now. I also put the impala rear disc on the blazer rearend and I want something bigger. The TTII's are fine but I want to run a 22" out back now and I think I am going to go with the centerline salt flats now on the blazer. I am going to fix the 67 up as a sweet driver that I can show but I am going to turn the blazer into something a little nicer. I would like to twin turbo the 283 in the 67 also but that is in the next 2 to 3 years.
Old 07-09-2007, 09:50 PM   #4
72CSTC5
72CSTC5's Avatar
Do it, I have been robbing parts off of my 2wd Blazer too for my 72 shorty
72CSTC5 is offline   Reply With Quote
Old 07-10-2007, 06:59 AM   #5
#2:The booster is good and I think that prop.-valve will do ya just fine.Does the`67 still have the original m/c?You`ll want the dual res. m/c.If you need to buy anything there just make sure you get it all matching.The plunger rod can vary and get your head scratchin`.I bought a booster/master cyl. unit from Napa to keep it simple.
Old 07-10-2007, 07:50 AM   #6
68speedalert
Semi-Senior Member
68speedalert's Avatar
..so I reuse the same plug in the 67 and just pull the terminals and replace them in the slots that gmc paul has listed?
Yes. the info he has (at least it was 2 years ago) is correct. It worked great when we did it. Take your time. I made a diagram of the connector and the wire colors of each version to keep it straight. Practice on the blazer on getting the terminal from the connector.
I don't think you can just swap the spindles. The ball joint and tie rod ends studs are a different diameter with the 71. You would be better to change out the complete sub-frame......or change all the upper and lower control arms and then use the 72 steering linkage. Is there power steering issues?
Booster will be fine, Why not use the master cylinder & the prop valve from the blazer? Those drum pieces are different from disc pieces. They may work, but would not be 'correct', for safety reasons.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 07-10-2007, 08:44 AM   #7
jkade
jkade's Avatar
I did the cluster swap last week and it went pretty easy. I gave the booster and master cylinder to Uncle when he came and picked up the BBC. I have a booster and master on a 91 suburban that I have been parting out so I may just use it and get the right porp valve. I did some more research on the disc swap last night and realized what you said is true about the steering and the ball joints on the disc swap. I think I will call around today and see about getting a complete setup out of a 87 down truck and leave the blazer's front in there since I hate to have to put the 67 setup back in it so I can move it around when needed. Thanks for the help
Old 07-10-2007, 11:12 AM   #8
72Cheyenne454
72Cheyenne454's Avatar
On a 4x4 Blazer, the rear end width (drum to drum) is different than a pick up rear end. Im assuming your Blazer is a 2x, so the rear end is most likely the same as a pick up. Double check just to make sure.
72Cheyenne454 is offline   Reply With Quote
Old 07-10-2007, 11:48 AM   #9
rlm316
rlm316's Avatar
If you are parting a '91 Suburban you can use the crossmember from that. Just make sure to use the steering components from the '91 also. I have a '91Suburban crossmember under the frame of my '70.
rlm316 is offline   Reply With Quote
Old 07-10-2007, 07:47 PM   #10
jkade
jkade's Avatar
The suburban is a 4x4, I called the junk yard today and they are getting me all the stuff on a 80's c10 for $200 bucks including the crossmember, arms, steering componets, spindles, drums and calipers. I think I am going to use the brake booster and master cylinder off the suburban though.
Old 07-10-2007, 08:27 PM   #11
bagged74
its just $$$$$
bagged74's Avatar
I have all brand new stuff on the front of my blazer that I could sell you. all new ball joints, tie rod ends, idler arm, 3" drop spindles, wheel bearings, and cross drilled rotors with new calipers good power steering box off an 87 burb and Por 15 coated control arms. I wont be using the stuff with my new set up. shoot me a PM if you are interested.
Old 07-11-2007, 12:15 AM   #12
68speedalert
Semi-Senior Member
Are you sure that will work? I know that the original 67-72 boosters are very different from the 73-up boosters.
Old 07-11-2007, 08:10 AM   #13
rlm316
rlm316's Avatar
I would use the booster/mastercylinder/ prop.valve from a '71-72 and the brake lines for the same 71-72. They are routed so much nicer on those than on the 73-87. With a small ammount of re-work the lines will look like a stock application. Here are somr pics of how I routed mine;
Old 07-11-2007, 08:13 AM   #14
jkade
jkade's Avatar
There is a thread in the Faq section that tells about doing the swap.
Old 07-11-2007, 08:19 AM   #15
jkade
jkade's Avatar
Attachment 281798
Attachment 281799
Attachment 281800
Attachment 281801
I think I am going to just make the suburban set up work for now, in the future I think I will probably convert to hydroboost on this truck as well and hate to spend the dough on the 71-71 and do away with it in a year or 2. Reckon I can make the 4x4 brake lines work off the 91 suburban?
Old 07-11-2007, 09:31 AM   #16
68speedalert
Semi-Senior Member
Since you're changing to hydro anyway, I would use the blazer stuff. It looks like quite a bit of bracket and rod work from the 91 compared to just R&R from the blazer.
rlm316....nice work. looks really clean. Your set-up is similar to his 91 4x4 routing.
Old 07-11-2007, 12:00 PM   #17
rlm316
rlm316's Avatar
68speedalert, thanks. I have a '85 C10 that I used as a guide. Everything for the steering is '91 so there was a need to reroute the hard lines for the hose location on the upper a-arms. There is a slotted hole in the frame that I used to pass the hose through. The outside threads on the hose are 9/16 id so I just used a flat washer and a nylon loc-nut to anchor it. The hardest thing was bending and reflaring the hard lines, they were originally for a '71-'72 power disc/drum truck.
Old 07-11-2007, 03:17 PM   #18
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
re idiot to gauge swap.
I used gmc paul's faq. Very simple, Easy to follow directions. Info was dead-on correct.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 07-11-2007, 03:39 PM   #19
jkade
jkade's Avatar
That is the directions I used to do the swap and it was fairly easy.
