Old 07-04-2007, 12:40 AM   #1
bufmatmuslepants
Junior Member
found a free NP241, quick queston though
buddy has a NP241 hell give me for free, what else would i need to use it to replace my NP203? are the driveshafts the same length? do i need an adaptor? he said he has the driveshafts from the blazer it came out of, will either one of them work?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 07-05-2007, 12:56 AM   #2
bufmatmuslepants
Junior Member
Re: found a free NP241, quick queston though
nobody has any idea? i have a 203 with a part time kit lined up to buy if i cant fit this 241 please help me figure out what i should do!
1994 Z28 M6
Old 07-05-2007, 12:57 AM   #3
1969k10stepside
You are better off asking this in the 4wd section...
1969k10stepside is offline   Reply With Quote
Old 07-05-2007, 01:24 AM   #4
bigtruck81
you just need the proper (TH400, or TH350, whichever the case) to NP208 or NP241 adapter. and make sure that the 241 came from behind a 700R4, if not, you'll have to change the input gear on the case.
bigtruck81 is offline   Reply With Quote
Old 07-05-2007, 09:28 PM   #5
Russell
Professional Grade
Russell's Avatar
An NP241 uses the same adapter as an NP208 does, and should directly replace one. There are 27 (I think) and 32 spline NP241s, you'd need a transmission with the same spline count to bolt it straight up.
I think that most if not all NP203s are 32 spline units, but I don't know if the adapters are the same or not.
The front driveshaft from the blazer should work in your truck, but you'll probally need to get the rear shaft's length changed. Does the NP241 have an electric speedo, or is it from an 89 with a mechanical speedo drive? Make sure you get the shifter assembly with it regardless of which way you go.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-05-2007, 10:06 PM   #6
bigtruck81
27 spline 203s are the most common (from behind TH350s), a 32 spline (TH400) 203 is a pretty rare and desirable piece, especially those looking to put a doubler behind a TH400
Old 07-06-2007, 01:18 AM   #7
Russell
Professional Grade
Russell's Avatar
Ah, almost all the 203s I've seen are from TH400s
Not that uncommon around here
