Old 07-04-2007, 11:32 AM   #1
67c-10Texas
Chevelle Header Install
With all the questions and postings about headers lately, I figured that I would take some pictures of the install last weekend and post them for you guys.
I bought these headers off of EBAY from Skip White Performance - Mid Length Chevelle Headers - Ceramic Coated - nice quality - price was under 200
First off let me say that I am using tublar motor mounts. I have no idea if these headers will fit stock mounted motors
The headers fit nice with some light trimming of the upper frame edge
About 1/4" on the drivers side and a bit more than 3/8 on the passenger side.
Both of these are for a length of maybe 3 to 4 inches.
The headers are mid length and hang perfect in the frame rails. Any good muffler shop should be able to create a bend in even 3" that will stay in the frame
Sorry but I had to remove the clutch lever from the old saginaw so I don't think these will work with standards
I am pleased with the quality and would say that these are great addition on price alone. If they last 3 years I think that it will pay for its self. I would have much rather had a set of long tubes but finding a set that hangs high in the frame is near impossible.
I have some more pics if needed and can answer any questions
Thanks to the Board
67c-10Texas is offline   Reply With Quote
Old 07-04-2007, 11:41 AM   #2
s95930
A-Adam A-Adam
s95930's Avatar
Re: Chevelle Header Install
Thanks for the info.
Could you add some pictures from under the truck?
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 07-04-2007, 03:25 PM   #3
byrd
Union Electrician
byrd's Avatar
Will not work with stock motor mounts as I found out the hard way If you do a search you will find that some people have used them and they have worked,but not the ones Skip white sells. I ended up using the 88-95 headers he sells and they fit great, with a slight trim of the DS rail on top only(about 1/8" trimmed off) You can check them out in my build thread in my sig if anybody wants to see what they look like...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-04-2007, 05:12 PM   #4
67c-10Texas
more pics -
Old 07-04-2007, 06:46 PM   #5
72hotrod
72hotrod's Avatar
I had Hedman aluminum coated headers when running a small-block in my 72. I can't remember exactly the year application, but it was 64-69 (I think) full-length Chevelle. With the engine on 6-cyl stands in the 6-cyl position everything cleared great except the clutch linkage, but I fabbed up some and made it work. I didn't like the angle or position of the collector as it wasn't as level/parallel as I would like and was a little low. When I switched to BB on 72 mounts in the stock BB location, I tried the headers I had from a 77Grand Prix with a BB Chevy that were also full-length Hedman aluminized for 64-69 (I think) Chevelle.They fit great(one tight spot-no contact- by the rear bushing of the lower control arm on the DS) with TH400, but I never tried w/manual.They were't AS low as the SB ones, but I would still want a tighter, above-the-frame-bottom fit. I know they were both for a late 60's Chevelle applications. Those that you got first should (might) have worked with the engine set back in the 6-cyl position with 6-cyl stands. It's just a little tighter clearance at the firewall, but not a problem. I know it would be more helpful if I kept records so I could give a part#, or was more certain of the particulars like exact years, but I just play like a kid and don't much look back.
72hotrod is offline   Reply With Quote
Old 07-04-2007, 11:43 PM   #6
project1971
project1971's Avatar
I got the same ones. Hopefully installing them in the next few weeks. I have bought several things from Skip White and they all seem great.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 07-05-2007, 12:13 AM   #7
black05stxjt
looks good, what brand control arms are those?
black05stxjt is offline   Reply With Quote
Old 07-05-2007, 01:51 AM   #8
HUEVUDO
HUEVUDO's Avatar
I bought some ceramic coated headers for my yellow 67. Have not installed them yet....
HUEVUDO is offline   Reply With Quote
Old 07-05-2007, 02:12 AM   #9
cameeks
Long Fleet Club
cameeks's Avatar
I'm wanting to do this so I'll be watching this
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 07-05-2007, 10:32 AM   #10
rodstored-72
chevy truck fan
rodstored-72's Avatar
i believe that i have the same headers that i bought from summit & i have them on my 4.5" lowered (front) '72 chevy & they fit great with my stock motor towers & mounts. just ssome info. if wanted....
looks good!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 07-05-2007, 11:32 AM   #11
67c-10Texas
control arms are from chisholm enterprises - they are no longer in business
it was a swap meet find
Old 07-05-2007, 12:19 PM   #12
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Where did you get your tubular motor mounts from, just in case anybody here runs into the same problem...... Thanks..............Bamm
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 07-05-2007, 05:45 PM   #13
67c-10Texas
Sorry Bamm
i bought the tublar motor mounts from POL - Performance On Line
it was a kit that included the mounts, trans crossmember, and shock relocators (have not installed those yet shock mounts yet)
Old 04-05-2008, 12:39 AM   #14
HoupPhotography
What size motor is that?
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-05-2008, 01:52 AM   #15
67c-10Texas
small block
Old 10-13-2008, 08:16 PM   #16
sanchzy
i have a 70 but its bagged and ive though 3 pairs of headers and thay all too long or hit the top rail so im lookin for a shorty that would fit
sanchzy is offline   Reply With Quote
