Old 07-04-2007, 12:50 PM   #1
loader820
tail light
I have a problem, I have a chev C10 which my break lights, I check the turn signals and everythin i check the fuse and all the fuse are good but when i turn on the right turn signal the reverse light on the left side start to blink while the right side turn signal is on I have park lights but i dont have no brake light when could be the problem with the wiring is it the wiring in the back or is it the front where it can be the problem
loader820 is offline   Reply With Quote
Old 07-04-2007, 11:44 PM   #2
85 c-10
Re: tail light
I can not tell you enough, check every ground wire you have. Start at the back of the truck and look for every one. I had very dim brake lights. Turn the headlights on and it killed everything in the back. Use either turn signal and both lights flashed as if the flasher was being used. I found one bad ground and that fixed the whole thing.
Josh
85 c-10 is offline   Reply With Quote
Old 07-05-2007, 02:22 AM   #3
krue
Designated A-hole!
krue's Avatar
Re: tail light
Check grounds are good, and take an old battery post cleaning brush and clean all your bulb sockets.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
