Old 07-04-2007, 03:59 PM   #1
BCOWANWHEELS
Tilt Column Shift Indicator Light Out Help....
Hey Guys My Automatic Trans Gear Indicator Light Is Out On My Column. Anybody Know Where The Bulb Is And How Much I Have Todissasemble The Column To Change It ?
Bob In Tn.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 07-04-2007, 04:02 PM   #2
71tahoe
71tahoe's Avatar
Re: Tilt Column Shift Indicator Light Out Help....
If I'm not mistaken (someone correct me if I am) the shift indicator light had a fibre optic cable from one of the lamps in the dash.
71tahoe is offline   Reply With Quote
Old 07-04-2007, 04:05 PM   #3
71MUTT
Can't ReMember
71MUTT's Avatar
I know on my 71, it has a fiber type cable that runs light from the back of the dash panel.(gauge cluster) I think it hooks up to the light for the speedometer or gas gauge.
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 07-04-2007, 04:10 PM   #4
71MUTT
Can't ReMember
71MUTT's Avatar
Find the bulb in the dash that has the fiber optic wire hooked to it. That would be the one to change.
Old 07-04-2007, 04:12 PM   #5
Bob Moore
Wheels - Tilt columns use a regular bulb. It is located below the gear lens. 2 small phillips head screws will allow the lens housing to come off. The bulb is covered with a stainless piece that has a small slit that filters the light. Often times a green plastic cap also filters the brightness.
2 screws and a small pick is all you need.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-04-2007, 06:17 PM   #6
70GMCer
70GMCer's Avatar
That's how mine is
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-04-2007, 09:42 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
tilt is in the column, non tilt goes to the inst panel, should be the inner lamp on the fuel guage. if the dash lights work but no perndle light on a non tilt, then your fiber optic cable is either broken or disconnected.
Old 07-05-2007, 08:15 AM   #8
Huck
Huck's Avatar
No fiber optic on TILT columns. Just a small bulb mounted below the shift indicator. YOu might want to make sure the GREY wire is plugged into under the dash ---it is a single unique wire that comes down along with the tilt wiring harness. This wire is the source for the 12V going to the bulb. Make sure it is plugged in before you start taking things apart. Huck
Huck is offline   Reply With Quote
Old 07-05-2007, 11:38 AM   #9
BCOWANWHEELS
Huck,
Where Does The Gray Wire Plug Into Exactly ?
Thanks Guys
Bob
Old 07-05-2007, 12:20 PM   #10
Shock_Me
Shock_Me's Avatar
Bob,
It plugs into the fuse panel.
Pete
Shock_Me is offline   Reply With Quote
Old 07-05-2007, 02:23 PM   #11
BCOWANWHEELS
thanks pete. i,ll check it tonight. know exactly where on the pannel ?
bob
Old 07-05-2007, 10:23 PM   #12
BCOWANWHEELS
Well I Checked The Gray Wire For Hookup And It Wasnt Hooked Up. So I Hooked It Up Still No Light. So Then I Got My Test Light Out And I Do Have Power To The Center Terminal Of The Light Socket Now So This Means No Ground.... Where Does The Tilt Column Ground At. And I Did Install A New Bulb And Another One Also Just To Be Sure New Bulb Wasnt Bad. Wheres The Ground ??????? Socket Isnt Corroded.....
Bob
