Old 07-04-2007, 07:28 PM   #1
92470
Heat riser direction placement question
Hi, I have a 71' Cheyenne with a 350 SB that I am installing a stock heat riser on. Can anyone tell me if the couterweight and spring assembly on the heat riser is supposed to be on the front side of the manifold or the back when you install? You can bolt it up both ways, but I'm not sure which is right, and I can't find a picture. It's pretty easy to tell top and bottom, but front and back is confusing. Can anyone help me? Thanks
92470 is offline   Reply With Quote
Old 07-04-2007, 10:49 PM   #2
jhow66
jhow66's Avatar
Re: Heat riser direction placement question
Turn it to the outside. That way you can tell if it is open or shut.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-05-2007, 01:20 PM   #3
92470
Would bolting it up with the assembly on the outside have been as it was from the factory? I thought it was either facing the front, or the rear?
I'm sure it would work either way, but does anyone have a pic of one installed as original or know if on the side is correct? Replacing all of this is a pain, and I just want to make sure I do it right the first time! Thanks!
Old 07-05-2007, 01:24 PM   #4
john
member #16
john's Avatar
You could always reach it from the outside to see if it was free. Never saw one turned in.
john is offline   Reply With Quote
Old 07-05-2007, 07:11 PM   #5
Zeke
Active Member
Mine was installed angled to the back when I got the truck. don't think it was ever off from the condition of the exhaust system and the fact it was stuck partly closed.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
