Cab Mount Thickness?
I went to install my new cab mounts, and noticed that there are thick ones and thin ones. I did a search but couldn't get my answer as to which are front and which are rear. Any help would be great, thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Re: Cab Mount Thickness?
Which ones?
The 4 large diameter are the same thickness and fit between the cab and frame. The cone shaped ones get the longer metal sleeves inserted and sandwich the frame mount. The ones in the bottom row in the picture are the radiator support mounts and attach similarly using shorter metal sleeves. |
It's the air up here
on the cab, the thick ones go to the rear of the cab, and have a washered insert. the front cab mounts are the thin ones.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
#4 | |
It depends on which type mounts you have.
Stock rubber. Quote:
Polyurethane http://lmctruck.com/icatalog/cb/images/0107.jpg |
I agree, taller ones in the rear.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Thanks guys! That was my thoughts too, but I thought I'd better ask.
