whats the gear ratio?
I have a 77 3/4 ton 4x4 with a open rear end, whats the best way to figure out the gear ratio. thanks
65 tripower conv 4spd gto, 66gto, 67 gto 65 lemans conv 4spd 69 firebird conv. 67 c20 4x4 Last edited by goldengoat2; 07-04-2007 at 09:53 PM. |
Re: whats the gear ratio?
The only way to know for sure is remove cover and count the ring gear teeth and then the pinion gear teeth and divide.
You can lift the rear and turn the tire one revelution and count the number of turns of the driveline but not always accurate that way.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Or get the numbers off the ring gear and use this chart:
That's alot easier than counting teeth... Ratio 2.56:1 - Tooth Combination 41,16 Ratio 2.73:1 - Tooth Combination 41,15 Ratio 3.07:1 - Tooth Combination 43,14 Ratio 3.08:1 - Tooth Combination 40,13 Ratio 3.08:1 - Tooth Combination 37,12 Ratio 3.31:1 - Tooth Combination 43,13 Ratio 3.36:1 - Tooth Combination 37,11 Ratio 3.42:1 - Tooth Combination 41,12 Ratio 3.55:1 - Tooth Combination 39,11 Ratio 3.73:1 - Tooth Combination 41,11 Ratio 4.10:1 - Tooth Combination 41,10 Ratio 4.11:1 - Tooth Combination 37,9 |
Lift ONE tire only, then count driveshaft revolutions during TWO full rotations of the tire.
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Thanks everyone
65 tripower conv 4spd gto, 66gto, 67 gto 65 lemans conv 4spd 69 firebird conv. 67 c20 4x4 |
