07-05-2007, 05:19 AM | #1 |
So I think my TH350 is FUBAR
Well I think it is time for me to face the facts and pull the trans tomorrow. What do y'all think?
When I got the truck running it made a really high pitched whine like a gear drive was installed on the truck, but I figured it was the water pump / alternator as both accesories were old and sat around for a while. Well I replaced both (the WP bearing was pretty bad), got the truck running well and even fixed the brakes (sweet!). But the whine is still there but now it seems to go away after the truck warms up a bit and the truck has always had a whine when it is shut off that sounds like a jet engine slowing down (errrrrrrr stop). Now that I can actually drive this thing, I noticed that it does go into all gears, but Reverse takes a few seconds to engage sometimes AND upon acceleration makes the truck shudder real bad. Also, I know for a fact that the truck, when engaged in reverse, is NOT supposed to roll forward and it rolled a bit down my driveway (which is steep) while in reverse until I gave it some gas. AND Freeway speeds seem impossible! I mean I don't know what gears are in this truck (they feel like 4.11's?) or where to look for a ratio, but it seems like the truck won't do over 50MPH in third, but the motor sounds like it is doing ~3000RPM+ and going 100MPH. Truck is a '69 C10 SWB 350, short shaft TH350, just had the driveshaft fully rebuilt with spicer universals and a new carrier bearing. |
07-05-2007, 05:44 AM | #2 |
Designated A-hole!
Re: So I think my TH350 is FUBAR
I would at least drop the pan and check for metal before I pulled the tranny.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-05-2007, 06:23 AM | #3 | |
blood type; Retumbo
the whining is the pump being severly worn out. the :errrrrrr,stop" sounds like a sprag clutch gone sour. the reverse thing is an indicator that the clutches are real bad and the piston seals are done. (reverse always goes first due to it needing the highest volume of fluid) most tranny shops will do a bench job TH350 for around $400. |
07-05-2007, 07:38 AM | #4 |
its all about the +6 inches
however, the truck can easily roll forward in reverse, on a steep driveway.
I've had 2 fresh rebuilt Th350's, and 3 well worn ones, and they all did this. I agree with 68C15 1oo% That sucker is a gonner, but the jet turbine sound would be neet to screw with someone's head. |
07-05-2007, 07:57 AM | #5 |
I've heard many converters sound like that when they blow a thrust washer or spragg, it can also cause the rpm problem, they go from torque converter to fluid coupling.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
07-05-2007, 11:58 AM | #6 |
The Older Generation
If you're not sure what ratio your rear axle is there is a code stamped into the axle tube (see pics) and you can go here and look it up in the "axle" section. If your truck originally came with a six cyl it probably would have had a lower geared rear end. http://www.americanclassic.com/paint.htm LockDoc
07-05-2007, 01:57 PM | #7 |
My 70 C20 has a TH-400 but it had a whining noise like you describe. I thought I needed a new tranny too. I decided to drop the pan and do a filter and fluid change. I guess the filter was clogged because with a new filter and fluid, it makes no noise and works great.....I probably just got lucky but it's worth trying. IMHO.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
07-05-2007, 05:20 PM | #8 |
I forgot to mention earlier that I had done a complete fluid + filter change on the transmission prior to me driving it at all.
Now I take it that I also have a 4.11 rear as I suspected (thanks LockDoc!) but I have a 1970 rear instead of a 1969 I guess as the code is "TDB 0210". It definitely screwed with my head... Last edited by rough69; 07-05-2007 at 05:21 PM. |
07-05-2007, 05:41 PM | #9 |
Sounds to me like a bad converter or it's very low on fluid.
Either s/b an easy fix.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
07-05-2007, 08:17 PM | #10 |
It has the right amount of fluid in it still although the lines do leak so I ordered new ones that will be here next week.
I think it is entirely possible that the P.O. installed a new converter incorrectly as it is blue and has a drain plug on it upon further inspection. I'm going to pull the trans, get it redone and pick up a new converter (think I'll get a 2000 stall B&M like on my old truck), install it with the new lines and pray for the best! |
07-05-2007, 09:09 PM | #11 |
Location: vacaville ca, because it as far from indy as i can be
wtf? a drain plug on the converter!!!??!?
4.11 and 28" is 3000 at 50 the slow ingaugement and shuttering certainly sound like its dieing. the reverse roll is nothing. p/o could have installed a stall converter too, makes it spin to a higher rpm before it fully locks in. does the motor have a big cam? if it was installed wrong it would have bent the flexplate and broke the fluid pump drive. depending on where you live in cali, i have a 2wd th350 you can have to rebuild so yours isnt down extra time. you do know it takes somthing like 10-12q to refill and empty tranny right? Last edited by trkklr77; 07-05-2007 at 09:10 PM. |
07-06-2007, 12:46 AM | #12 |
dont take this the wrong way but you are checking the fluid level while its idleing in park right?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
07-06-2007, 03:34 AM | #13 |
Yes I am checking the fluid level when trans is hot and in Park and the level is fine, fluid looks ok.
The converter really does have a plug on it! I will take a pic of it tomorrow it is weird... I have 295/50/15 so a 26.6" tire with 4.11s and 65MPH is over 3500 RPM wow. Maybe I should slap in an overdrive box? Last edited by rough69; 07-06-2007 at 03:41 AM. |
07-06-2007, 08:35 AM | #14 | |
I saw them mostly on Ford trucks.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-06-2007, 11:35 AM | #15 |
Well here is a shot of my "Ford Truck" converter then
The more I think about it, a 200-4R swap is sounding pretty good, provided I can score one and afford the more expensive rebuild and other parts. For how cheap it is I'll probably get this TH350 rebuilt and keep running with it, I can always swap rear ends later... Last edited by rough69; 10-10-2010 at 11:34 PM. |
07-06-2007, 02:03 PM | #16 |
The PO probably drilled and tapped it. We used to have kits for doing this but if my memory serves me (for once) the kits had a very small allen plug that fit in the hole. I guess that balance was an issue. Spinning at 5000 RPM,that bolt the guy put in there is possibly going to cause vibration,etc. I don't know.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
