![]() Join Date: Jul 2000
66 Fleetside license plate bracket
Will someone please post a picture showing how a 66 Fleetside rear license plate bracket is attached to a stock non-step bumper?
Thanks.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: 66 Fleetside license plate bracket
Or not.
Slots go on anything!
I think they are just usually bolted right through the bumper.
I tried looking everywhere, i can't find it!
Easy Does It
You can align the plate to the metal strip under the tailgate, then mark 2 locations to drill holes for the plate,then bolt on. Then attach bracket to the bottom holes on the plate, this is how I did mine.
Keepin it old school
Brawley, I know this is a old thread but I have seen you post lately. So I know your still around..lol. Would it be possible to get a picture to see how your license light looks mounted how you described? This is how I'm thinking of doing mine. Thanks !
This picture is not really close enough to show the details, however there are two square holes in the flat portion of the bumper and two holes in the lower portion of the license plate bracket. I have installed several of these brackets and had to insert a spacer on the underside of the bumper and the top side of the bracket, in order to get the bracket low enough for the license plate to clear the bottom of the tailgate.
You can also drill holes in the cross sill to accept the bracket, however I don't like drilling holes in factory sheetmetal, so I do it as explained above. The spacer ends up being about 3/4" long to allow the license plate to clear. I hope this helps and good luck with your project. |
Easy Does It
sorry Bazooka but I have since sold the 65' , and now have a new project it's a 63'. To be honest unless you just want to have the license lights ,I would not use one, just bolt it straight thru the rear cross brace-unless you don't want holes in it.
#9 | |
Thanks everybody Last edited by Bazooka; 08-02-2008 at 05:23 PM. |
