Gettinlow & Goinfast
bagged truck need headers that clear!! help!!
my 78 is body dropped and i heard there are some camaro headers that will fit? any one know a part # or have any suggestions? thanks in advance.
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
Re: bagged truck need headers that clear!! help!!
i have long tubes but they hang down too far. i need some thing that is a mid length or shorty header. here is a little teaser to get ya'll motivated to help. thanks
Chris
Have you tried summit racing for some shorties for a truck or mid length's?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
looked at some but no one there can say if they will work or give me some specs so i can measure it
On a budget like Fred Sanford
Pretty sure these will be what you're after, they're 3/4 length chevelle headers. The ebay seller is a standup group, I've purchased many things from them. I've got a set of stainless longtubes for our trucks from these guys, the quality and price can't be beat.
http://cgi.ebay.com/ebaymotors/CAMAR...33330882QQrdZ1
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
i have shorties.but not bagged.what kinda measurments are you looking for? ground clearence i'm bettin.i'm about 5 in drop in front,my a arms are still the lowest point.let me know if i can measure sumpin for ya.
" Never look up a dead dogs butt."
paper or plastic?
I just put headman shorties on my 86. They fit great and you should have plenty of room for ground clearance. I got them from summit racing.
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
i need some thing that stays abover the rocker. my frame is set up level with the rocker then plated with 1/2 in.
boatpuller. see if your headers stay above your rockers??
#9 | |
Pretty sure they're above the frame, I'll check this evening and snap a pic. They tuck higher than any other longtube I've run by probably 2-3".
Chris
I don't see why ANY listed shorty or mid length headers ANYONE sells that fits your year truck with your motor, say sbc 283-400 and 73-87 1/2 ton 2wd, or whatever they have it listed as, wouldn't fit.
I mean a shorty header, most don't even come past the oil pan let alone the frame rails, you run your pipes as close to the floor as you want after that.
#12 | |
thanks for all the info so far !!
#13 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The ones you want are 3/4 length for a Chevelle for SBC.
This is the PN for the black coated ones: WLK-85118 This is the PN for the ceramic coated ones: WLK-86118
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#14 |
Chris
So no one makes a shorty for a fullsize truck or blazer?
#15 |
It followed me home?
Here's a set of sanderson shorties I had on my 85
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#16 | |
paper or plastic?
#17 |
summits got hedman elite shorties.ceramic.heavy flange,ball and socket collector.just ask for 73-87 c 10 2 wd.thats what i did.anyway ,lownfast.here's a couple of pics.the passenger side is under tranny cross.i'm not sure why the dude did it that way,but i'm sure he had a reason.he does good work,i just stuck headers on there and took it to the shop for flowmasters and custom dual.i did notch the frame on pass. side when motor torqued it rubbed header.pretty tight on that spot.,you can see it in the pic's.the one underneath shot's blurry but you get the idea.hope that helps.
#18 |
I have a set of Hedman 69648 Elite shorties for my 68. They should work well with the 73-87's. I really like these headers, 3/8" flanges, ball flange collecters, and 5 yr warranty on the thermal coating.
| Bookmarks |
