Old 07-05-2007, 02:49 PM   #1
Truckstr
Truckstr's Avatar
Question Performance Disc Brake Calipers for our trucks
Probably should have posted this thread in here instead: http://67-72chevytrucks.com/vboard/s...d.php?t=248113.
I'm looking to find out if there are any bolt-in caliper upgrades for our trucks.
Mine has the ECE 2-1/2" dropped spindles that use the '72 disc brake calipers. I'm using the 11-7/8" diam. Summit Racing drilled/slotted rotors. Are there other, better calipers that fit? Wilwood GMIIIs or?
Thanks, ya'll!
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 07-06-2007, 09:35 AM   #2
Truckstr
Truckstr's Avatar
Re: Performance Disc Brake Calipers for our trucks
Does anybody know if the calipers from an ’82 Suburban, 3/4-ton, JD7 option, (Car Quest reman. 16-4122/16-4123) fit in place of the '72 C-10 calipers?
The '72 C10 calipers have a 2-3/4" diameter piston. The '82 Suburban JD7 option caliers have a 3-5/8" piston.
If they are interchangeable (different banjo bolt, and?), I may have to change out the master cylinder. I don't know about that yet.
Jeff
Old 09-20-2007, 01:17 AM   #3
Captainfab
60-66 Nut
Any updated info on this? I also read somewhere about the JD7 option brake calipers, and as I understood they were a bolt in swap. I did a search to try and find the original post but this thread was the only result.
Old 09-20-2007, 06:21 AM   #4
chevy72blu
chevy72blu's Avatar
interesting..
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 09-20-2007, 08:11 AM   #5
Truckstr
Truckstr's Avatar
No, not yet. I've been concentrating on putting glock35ipsc's rear disc brake "kit" on. It uses the '95 Camaro Z/28 calipers and Impala SS rotors. Sweet setup.
As far as I've been able to determine the JD7 calipers will work, but the piston may overhang the pads. That wouldn't necessarily be a good thing due to uneven or excessive wear on the pads. I'm just going to have to take the spindle and rotor setup to the auto parts store and check it out. Now, to find an auto parts store that has JD7 clipers in stock.
Jeff
Old 09-20-2007, 08:29 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Originally Posted by chevy72blu View Post
interesting..
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-20-2007, 08:45 AM   #7
jkaylor68gmc
jkaylor68gmc's Avatar
Brothers new catlaog has a set of twin piston polished aluminum ones for 299.99
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-27-2007, 08:36 PM   #8
Jvan
Truckstr, Where Did You Get The Rear Kit/
Jvan is offline   Reply With Quote
Old 09-27-2007, 08:48 PM   #9
Truckstr
Truckstr's Avatar
glock35ipsc was/is selling the brackets. You just use the rear disc brake calipers (right and left) from a ~'95 Camaro Z-28 and the disc brake rotors from a ~'95 Impala SS (again, right and left). You have to use 5 on 5" axles. I have a '67 so I had to get aftermarket axles. I already had 'em since I was changing over to 5 lugs anyway. The only "glitch" that I've come across is that the rotors OR the axles have to either be ground or cut down to allow the rotor to slip over the raised portion of the axle center. I'm having my axle centers cut down so that when and if I need new rotors, then they'll be bolt-on.
Look for posts by glock. He posted a good thread about it with pics.
Jeff
Old 09-28-2007, 01:32 PM   #10
Scott68-93-97
Scott68-93-97's Avatar
kore 3 products makes c5 c6 corvette brake conversions for a lot of vehicles except they dont say corvette, even though they come through the same manufacter since there not marketed through GM they cant use the logo,
Also aerospace componts has a sweet setup you can buy them through ECE but there very very expensive, there the brakes used on the copperhead project stacey david did when he still hosted trucks
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-28-2007, 01:35 PM   #11
Scott68-93-97
For the 6 luggers out there if you buy a bracket in the rear and use GM front metric calipers ie; malibu, monte carlo late 70's 80's or caddy rears with e brake you can run 88-98 4x4 front rotors on the back and keep your six lug
Old 09-30-2007, 02:01 AM   #12
Chevysdominate
Chevysdominate's Avatar
According to the description these should work. Not sure of the quality or effectiveness though.
http://cgi.ebay.com/ebaymotors/47-87...temZ8027443186
Chevysdominate is offline   Reply With Quote
Old 09-30-2007, 06:04 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Those are the ones in the Brothers catalog- $399...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-03-2007, 05:24 PM   #14
Scott68-93-97
An ammendment to the previous post you have to modify the 4x4 rotors to fit over the axle center hub you can buy the brackets and modified rotors here http://tsmmfg.com/2531.htm and some junkyard calipers your in it a little over $300 not bad considering your other options, I do like those pretty calipers off ebay though
Old 10-03-2007, 05:33 PM   #15
Truckstr
Truckstr's Avatar
I'll keep that in mind, Scott. Thanks.
Jeff
Old 10-03-2007, 09:50 PM   #16
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my '01 GMC had dual piston calipers up front. thats the kind of upgrade I'd like to make on mine if its possible.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-08-2007, 02:16 AM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Had a minor revelation upon further study of the Brothers calipers. They are the Howe Racing calipers with the name ground off- hence the reason the front section is polished- they had to hide the grinding marks some way...
Oh yeah, the Howes can be had all day long for $100 each brand new, cheaper used on racingjunk.com. Much better than the $399 Brothers wants.
-Chris
Old 11-08-2007, 09:23 AM   #18
71Dragtruck
71Dragtruck's Avatar
Right on! Your the MAN! Do these just use the stock type pad for our trucks? Would you happen to have a part # for them? Mine is a 1971 GMC with stock front disc brakes 5x5 pattern, will these bolt right on?
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-08-2007, 09:46 AM   #19
Truckstr
Truckstr's Avatar
When the description says, "directly replaces the D52 GM caliper"; I have to make a couple of assumptions. First off, are the calipers that fit the '72 Chevy 1/2 ton truck the D52 calipers? It seems so. If so, then the D52 calipers are single piston calipers. So, will the Howe racing dual piston calipers directly replace the D52 GM calipers?
Hmmmm. Sounds like you've raised some good questions with your research. Thanks, gringoloco!
Now I've got to find the answers.
Howe racing's phone number is (989) 435-7080. I'll be checking.
Just FYI (a couple of the guys I work with were asking). 'Why' would anyone want dual piston calipers over single piston calipers? Answer: Dual pistons offer more piston surface area over their single piston brethren. Therefore, they allow the force on the pad to be distributed more evenly. Comparing two calipers with two different piston areas - the single piston caliper being the smaller area of the two, for this comparison - shows that less pressure will be required to be applied to the larger area to put the same pressure on the caliper. (BTW, there are also reasons why NOT to go with dual piston calipers. I'll leave that for another day).
BUT, the Howe dual piston calipers are offered in 3 different sizes: 2.125", 1.875" and 1.625". The stock '72 Chevy 1/2 ton truck calipers have a 2.75" piston. So, using the mathematical formula for the area of a circle (the piston) - pi times the radius squared or pi times the diameter squared divided by 4 - shows that the stock 2.75" piston has an area of 5.94 square inches. The Howe dual 2.125" piston calipers have a 7.094 square inch area. Good to go; right? Be careful, though. The dual 1.875" piston calipers have an area of 5.52 square inches, which is LESS than the stock GM single piston truck calipers! The dual 1.625" piston calipers have even less at 4.14 square inches. No good (i.e., not superior to the stock calipers). In contrast, the JD7 single piston caliper has 10.32 square inches of area. Wow!
So, if the Howe calipers fit, and you want better than stock, then choose the Howe calipers with dual 2.125" pistons.
Just for giggles, check out this site for more braking calcs and info: http://www.teamscr.com/grmbrakes.htm
Jeff
Old 11-08-2007, 10:21 AM   #20
revn67
revn67's Avatar
hey gringoloco, where did you see the pricing for these calipers? i went on the howeracing site and there aren't any prices....i'm very interested in these calipers!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 11-08-2007, 11:19 AM   #21
71Dragtruck
Summit Racing
http://store.summitracing.com/partde...5&autoview=sku
Sponsored by:
Hard Candy Customs
Old 11-08-2007, 01:55 PM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
Same pad. The 2 1/8" piston bores w/ 1.25 rotors are PN 33701. They are a mostly bolt-on item- see below.
Yes. This is a generic designation for the pad size/mounting bolt spacing. They were used on all kinds of things from small to midsize cars, trucks, and vans.
Yes. But, and there's always a but, there may be minor clearancing required to the spindle depending on application. I think the Brothers description even says this.
Exactly.
They are everywhere- eBay, racingjunk, Summit, Jegs, other vendors- do a Google search. I even found a set for $80 used, and the rebuild kits for these things are cheap!
Couple of things to mention for anyone considering these:
The good:
- More surface area= potentially more braking force
- They will fit the larger D61 "cop car" pads
- Light weight, ~5lbs each- say that about your cast iron stockers...
- They just look cool
The bad:
- The aforementioned clearancing of the spindle. From what I gather, it is very minimal.
- You will have to swap brake hoses. They have an 1/8NPT fitting. Hoses are readily available shelf items.
- The slider mounting bolts are not bushing mounted like stock calipers- you may get a little noise out of them, but to what extent I'm not sure.
- Larger bore master cylinder 'may' be required.
If you're going through this trouble though, you probably are upgrading to rear discs too which means you can use the bolt-in Corvette master. It attaches directly to your stock booster. I have something else in mind for this using a small diameter Fiero booster and using one of the tricks from Fiero 'hotrodders', a late model truck master with a 1 1/4" bore.
-Chris
Old 11-08-2007, 02:03 PM   #23
Truckstr
Truckstr's Avatar
Thank you, gringoloco. You da man!
Jeff
Old 11-08-2007, 02:45 PM   #24
Ackattack
Ackattack's Avatar
I've also been looking at some upgraded pads to go along with upgraded calipers. It looks like EBC brand DP71145 might fit my bill. A little better pad with low dust.
Ackattack is offline   Reply With Quote
Old 11-08-2007, 03:12 PM   #25
71Dragtruck
Thanks for the info, one last question, my brakes are manual and staying that way for drag racing, I'm going to Willwood discs for a 9" in the back also so might need the bigger master. Is there a higher volume bolt on master available? If once again the Corvette master, what year?
Sponsored by:
Hard Candy Customs
