Old 07-05-2007, 04:41 PM   #1
424shee
trailing arms vs leaf springs
I have a 70 gmc and awhile back I bought a trailing arm setup out of a longbox.I plan on putting airbags on this truck and after reading another post I'm wondering if I screwed up by buying these.will the trailing arms off a longbed work or are they longer than the shortbox ones.also would I be better off using the leafspring setup?what's the pros and cons?thanks
424shee is offline   Reply With Quote
Old 07-05-2007, 04:42 PM   #2
1969k10stepside
Re: trailing arms vs leaf springs
The trailing arms are the same regardless of whether it was a long bed or shortbed
1969k10stepside is offline   Reply With Quote
Old 07-06-2007, 09:42 AM   #3
Truckstr
Truckstr's Avatar
Did you just get the truck arms or did you get the rest of the brackets, etc., from the other truck frame? It's going to be a lot of work to change over.
As for which is better - leafs or coils - it depends on your intended use. For heavy laods in the bed, the leafs would be better, IMHO. Now, I've had 2 and 1/2 rick of wet hickory firewood in the back of my '72 w/ the heavy duty coils, but I didn't have hardly any spring left. I wouldn't recommend it.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 07-09-2007, 10:27 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
You'll be able to drop it lower and easier with the trailing arm/coil spring set up. I am going that route with my 72 GMC longbed.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
