another strike against LMC
Some of you might remember that I had a tail light problem a couple of months ago. I replaced the tail light harness with one from LMC and fixed a section of wire where someone had hacked in a splice for trailor lights and it was corroded. Brake lights worked for awhile and then went out again. I pretty much didn't mess with it cause of busy life stuff and the horrer of chasing down a short. I finally got around to lookin at it today and after checking everything that i could check, I finally made it back to the tailights and the brake light bulb was loose. I took the bulb out and jimmy rigged the connector to make the bulb fit tighter. EUREKA! All this time and it was only a loose brake light harness. It'll be the last item I'll buy from LMC.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
| Bookmarks |
