Old 07-05-2007, 09:13 PM   #1
82GMC4X4
82GMC4X4's Avatar
Famous Gas Gauge problem
I have searched and searched on the board and still couldnt find what I was looking for.
I have an 82 with the tual tank setup. The original owner had problems with the tanks and decided to only replace the one tank on the passenger side. The gas gauge how ever does not work. I have dropped this tank every weekend since I have gotten it ( I could probly do it blindfolded now). sender is grounded, (sender is less then a year old so I doubt there is a problem there) sender is hooked up. The only thing I can think of now is maybe something was not connected to the gauge itself. The tank switch has been disconnected, and no gas lines go to the other tank, although it is still there. Does anyone have any wiring diagrams for the gauges and sender wires?
82GMC4X4 is offline   Reply With Quote
Old 07-05-2007, 11:38 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Famous Gas Gauge problem
82GMC -
Here's a thread in a thread that you can pull on to see the wiring diagram ...
http://67-72chevytrucks.com/vboard/s...highlight=fuel
And, here's more threads within a thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219395
And more,
http://67-72chevytrucks.com/vboard/s...d.php?t=179942
Is your fuel tank selector valve working?
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 07-06-2007, 02:22 AM   #3
82GMC4X4
82GMC4X4's Avatar
i wouldnt know cause it was disconnected because I only haveone working tank. The tank was plumbed straight to the fuel pump? haha the gas lines were totally removed the tank that doesnt work.
Old 07-06-2007, 07:15 AM   #4
knightlife
Dark Heart Motorsports
knightlife's Avatar
do a wire check from the tank switchover on the dash to the back of the gauge bezel... thats about all I can think of from what you told meh...
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 07-07-2007, 02:40 AM   #5
boxrodz
boxrodz's Avatar
Did the wiring diagram help?
If the fuel tank selector valve is not present, then maybe the fuel gauge was never rewired directly to the sending unit.
boxRODz
Old 07-07-2007, 05:14 AM   #6
82GMC4X4
82GMC4X4's Avatar
Thats what I was thinking, thanks for the diagram, I havent had the chance to tinker with it yet, ill let you know what happens
Old 07-07-2007, 12:25 PM   #7
wedgemon
wedgemon's Avatar
These trucks were set up with a default tank; set to switch over if there's a short in the tank switch system. On mine(1980K10) it's the Right tank. You may think you're on one tank when in fact you are on the default.
Worth investigating...
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 07-07-2007, 07:14 PM   #8
jokersbowtie
jokersbowtie's Avatar
Hmmm i only have a single tank. fill it up and it goes to 3/8 is this the sending unit or the guage?
jokersbowtie is offline   Reply With Quote
