help
the P.O did a hack job on the truck and pulled the gas tank out from behind the seat and put a tank in the bed of the truck its all bolted in and safe(so they say) and under the cab pass side right below where the 2 rubber groumets are the have the return line the the fuel feed line then they have one that has just been criped off and it a steal line the what i think is the brake line
whats the 3rd line of the bunch and should it be hooked back up some were? i am just getting in to this thing and i will mostlike have more question on it thanks Last edited by wannabelow; 07-06-2007 at 01:09 AM. |
Re: help
From your description, my guess is that the third line is the vapor line for the charcoal canister.
What diameter is it? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
blood type; Retumbo
Re: help
3rd line comes from the tank and goes to the charcoal canister. this will probably be eliminated unless the rear tank has a spot for it.
Re: help
thanks
