Old 07-06-2007, 01:02 PM   #1
2bits
2bits's Avatar
250 timing question
I just dropped in a new (used) inline 6 and I KNOW I didn't back up the distributor a tooth when reinstalling the distributor. You know what I mean when you pull it out and you put it back it will always move a tooth. Well, I thought I didn't need to worry about it, I would just adjust it out with the timing. Well, we started it, and the engine ran beautiful. I mean smooth as silk. When I started to drive it, it clattered big time like timing was way advanced. I backed it off ALOT enought to where I would think it would compensate for it being moved a notch (yes it is all the way in).
My problem is that when I killed the engine, it ran on and on and on and on and on and on and on and on. You get the picture, we couldn't kill it for at least 60 seconds, I was freaking out.
Am I wrong that I can't just adjust it out to compansate, or do I really need to pull the dizzy and manually move the oil pump back a little?
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 07-06-2007, 01:27 PM   #2
Luvlegs
Luvlegs's Avatar
Re: 250 timing question
Electronic now right? I just tried that yesterday - It would diesel when I had the dizzy turned too far - I didn't get any back fire though as I went the other way. It ran smooth, I could rev it nicely but when on the road, it had a shake to it and wouldn't get over 50 - I pulled it, stuck it back it in... same thing - I can't seem to get it out with almost a 3/4 turn of the dizzy...
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-06-2007, 01:33 PM   #3
2bits
2bits's Avatar
Yes, the engine came with a points distributor, the truck was already wired and set up for HEI, so I upgraded the engine.
Also, I was researching some old posts, and I wanted to mention that I don't have a ground strap attached. I have never used a ground strap in my life actually with no problems, but I have always put the negative wire from the battery on the engine. This time my buddies convinced me to put it on the frame, could that freak something out? Yes, I will put a ground strap on it now anyway tho
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 07-06-2007, 01:38 PM   #4
Luvlegs
Luvlegs's Avatar
I can't say for sure if the ground would make a difference but I think the run on is a timing issue.... then again, If the ignition is turned off, there shouldn't be any power to the coil so - no spark.. but, if it's mis-firing, perhaps that's where it's getting the spark? not sure... if nothing else, this will keep this up to the top....
1972 C10 L6 3OTT
Old 07-06-2007, 01:47 PM   #5
2bits
2bits's Avatar
I guess my main question is do I really have to reset the dizzy back a tooth, or can it be compensated by turning it? I've got plenty of turning room, I am just scared to start it again.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 07-06-2007, 02:02 PM   #6
cwilli84
1FINE69
cwilli84's Avatar
Just a quick note. Are your plugs setup for an HEI or the old points system? The reason I mention it is they may be hot enough (or too hot) to produce the dieseling effect you mention , in which case they don't need to spark. Just hot enough to ignite the mixture. Anyway just a thought.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 07-06-2007, 02:50 PM   #7
Luvlegs
Luvlegs's Avatar
I gapped mine to 45.... did you regapped yours 2bits?
1972 C10 L6 3OTT
Old 07-06-2007, 03:03 PM   #8
2bits
2bits's Avatar
I took my brand new plugs from my bad engine (HEI plugs) and they are gapped at 45 also, good idea though... AC R45TS
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 07-07-2007, 12:40 AM   #9
2bits
2bits's Avatar
Didn't get an answer, so I said to heck with it and I started from scratch and yanked the dizzy, set TDC, etc and it is now purring like a kitten for the first time since I bought it... Finally!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 07-07-2007, 07:42 AM   #10
71tahoe
71tahoe's Avatar
My timing headaches are always skull crushers too. I may get to the point where I can start my son's 350 this weekend or next. Starting with a crate engine and a gutted HEI. I'm glad to hear you got it running.
71tahoe is offline   Reply With Quote
Old 07-07-2007, 07:37 PM   #11
2bits
2bits's Avatar
Ha! Yeah, this last engine I had in there was a skull crusher. Fixing the problem is just nuts and bolts but actually finding out what the problem is can be the real challenge. I know now I have bad piston ring in the old engine, but I don't know what else. I am interested to take it apart in the fall once it cools off. I've been driving around all morning! I love it! Good luck on your son's truck and thanks!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
