black rtv or red?
i picked this up to use because i am putting in a new intake manifold this weekend:
http://www.jamestowndistributors.com...pid=8625&PTECH i was reading previous posts and most people say to use the black rtv. is this what they are talking about: http://www.jamestowndistributors.com...ilicone+Gasket i went with the red because it is for high temp. why do most of you guys recommend the black? |
Re: black rtv or red?
I personally have quit using RTV all together. I now use only Mega Grey Import gasket maker or Mega Black gasket maker. I have had much better results with these and they don't stink like RTV.
is this what you use?
http://www.itwconsumer.com/catalog.aspx?prodID=2 where do you get it? and can i put that on the bolts, or should i use a teflon sealent? |
F.A.S.T. president
![]() Join Date: Sep 2003
The prematex ultra series has been the best I've found to date. Its alot stickier and more duarble then the standard RTV. It comes in black and high temp copper.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 07-06-2007 at 02:51 PM. |
#5 | |
Prestige member Old Farts Club
Hey sombodys gotta do it! ![]() |
Parts and more parts
For engine assembly, I have shifted over to the NAPA "Right Stuff" adhesive. It is an outstnding product, in my book.
![]() Join Date: Mar 2003
Permatex ultra grey or black--------------period
#8 | |
18 Till I Die
Clean the intake bolts really well and use a Teflon sealer like you use one water pump bolts. Then run a bead of black sealer on the front and back of the block and toss the rubber ones that come with the set. Add the intake gaskets nice and clean and use no sealer on these. Drop on intake and torque to spec. Once you drop it on there's no removing or you will have to clean the black silicone off and start over.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
silicone the bolts that go near the water chambers too,
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#11 | |
http://67-72chevytrucks.com/vboard/a.../t-225820.html and he had put the sealer on the gasket. the instructions that came with the manifold said to do this as well. |
#12 | ||
Semi-Senior Member
![]() Quote:
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab Last edited by 68speedalert; 07-07-2007 at 12:32 AM. |
#13 |
Long Fleet Club
The high temp is mainly for the exhaust. Your intake should never see those kinds of temps.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
#14 |
Old Skool Club
![]() Join Date: Jun 2001
Watch out for RTV...room temperature vulcanizing...products. Some are for automotive use. The problem is that as they cure, they can corrode the surfaces on which you put them, i.e., using them around a windshield and letting it contact the metal of the body. This may not affect any of the engine work, but the manufacturers specify what you should be using for a given task.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
![]() Join Date: Sep 2005
black rtv the high temp is what i use
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#16 |
"rite stuff"
http://www.partsamerica.com/ProductD...egoryCode=2132 It ussually runs about 11-13 a can. I have found it at advance auto and napas. I quit using silicone rtv when I found out about this stuff.
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 07-07-2007 at 12:20 PM. |
#17 |
18 Till I Die
You shouldn't have to give the gaskets any coating. If you get the Fel-pro ones they are designed so seal with no silicone.,also it makes the gaskets tend to "slide out" when you torque them. Also i never use silicone on the bolts. GM has always used a Teflon sealer like the plumbers white stuff to seal the bolt threads.
